H22A engine smoking when use vtec...anyone?
TypicalGuy
1,112
at nite..i tried to rev dat honda H22A 1st gear till 3rd gear till vtec open..then i stop and try to look at the engine..i jz rev once only..
then i can white smoke coming out from the engine block,no so much but got smoke like cigi smoke..so smelly ler the smoke..like burning rubber or dunno lar..
what is the problem
radiator no overheat also...
thanx
shiroitenshi
3,677
170
Just my guess.
VTEC solenoid opens, gasket leaks, oil gets onto heat sheilding wrapper on the exhaust header.. poof smoke!
could be other thing.. I'm just guessing.. (O_o)
mrbear
965
burn gasket? the head cover is not tighten up properly? might be the oil is burning? might be some other reason. is the temp shoot high?
err.. many2 reason. might be other H22A expert can explain.
coz i know white smoke will only come out only early in the morning. hehe
or white smoke if the piston/valve/seals/piston ring is worn out.
darkemperor
318
shiroitenshi said:
Just my guess.
second u....
nyway can trace any leakage found on the engine......
hisha
2,016
7
white smoke = engine oil is burning
black smoke = fuel too much ..not finish burn
bro did ur problem solve ?
patrickchong
349
1st just check for anything is leaking from engine gasket from any part even water or oil, if yes, then need change the gasket. almost its bcoz of leaking. if gasket burn also there will be leaking.
TypicalGuy
1,112
the car so old d...sure got little oil leaking...
when drive the car like normal ..nothing happen
it only happenned when i rev till it open vtec then check the engine..it's very very hot and white smoke come out from the engine block....even the word dohc VTEC also can see smoke come out..
the block very hot...
exhaust no smoke come out ler....
water temp also normal..
so what is the problem?
if engine overheat..the engine oil much be thick or dark color..but the oil also like normal..
is it the engine got little engine oil leaking so..the leaking oil gets to hot..so it evaporate?
mrbear
965
ha.. might be ur cover got small crack? that y got smoke.
as i know last 2 weeks went to my mech. he open my cover to change my vtec solenoid gasket. i see those white smoke coming out from the block. but that time my cover have been open n remove.
im really sure ur cover got cracked.
aloo all...peace yo....wts all this stuff...
1.ecu sohc civic ek/ej so4
2.tail lamp ek 96 spec red white
3.original ek 96 spec rear bonnet,black colour
4.original ek 96 spec rear bumper
5.air ram stainless steel 2",currently used at sohc civic
6.original mugen air filter swivel type
7.Fuel pump honda accord
8.ek 99 spec grill TDM ,champion white colour
9.sohc civic manual flywheel
10. honda ek/eg/dc wiper tank
11.Starter civic sohc auto
12.gear lever auto
13.original rear tail...
