- Joined
- Jul 4, 2006
- Messages
- 1,138
- Points
- 1,648
just got my kenwood kdc-x7529
im very messed up with the setting... first when i was in default setting, i just play with the amp hp setting and tweeter positioning and i can get to listen to "reverb" effect , the distance of the singer behind the mic ( is tis call depth?) and the sound of voice bounces left and right from a borrowed copy of chesky records cd.... but when i set my amp to full pass and try to control everything from the hu, i lose my left and right effect.. only can listen the position of the stage of near and far....and the sound effect distance (the so-called depth .. i tink) is nearer..meaning to say its loosing the effect of the sound coming from the imaginary suprano singing several feet behind the mic...is all this differant effect called imaging?
this is my current setting maybe anyone of you could correct me i did something silly on my learning process...
bass centre frequency- 60hz
bass Q factor - 1.25
bass extention- duno wat the hell is this i put it to off as default
mid centre frequency - 1khz
mid Q factor - 1.0
treble centre frequency - 12.5khz
my front and rear HP on the HU is set on 60hz and my sub pre out i set it to full pass and i adjust using my para EQ.
the above setting is done with my amp being set to full pass.
however .. during the first time i get those effect of near,far,left and right effect of a music i found out that the singing isnt too natural....why ah? issit the mid frequency is too high? default it came as 1khz.....
btw wat does centre frequency means anyway? does it mean fixed frequency?
im blurred and sound weired....
mid Q factor - 1.0
