Carburetor Section
What is wrong with this PLUG ... When it took out from my car's engine ..
It looks like this .. If long time didn't take out .. It will got THICK carbon stick on the plug leg ...
Piston ring worn ?? valve seal worn ?? F**ck the machanic who did top overhaul ... It worse than before overhaul ..notice white smoke when engine is running.. Before overhaul is one story .. after the overhaul another story .. What no warranty for overhaul...
Could it be a fuel too rich ?? or too lean ??? please all sifu help ...
http://img172.exs.cx/img172/5563/scn0991plug4cz.jpg
looks liek you're running lean..that si why theres many carbon builds up...
what's your comsumption..high or low?
The picture below shown engine's cylinder head .. I want to ask all sifu .. If i remove the nuts and the shaft on the red box area .. without touch and remove the camshaft .. were it affects the valves open and close timing ?? Coz if it is valve seal worn .. I was thinking want buy the good valve seal and DIY ... Coz i know got a tool can open valve spring to change valve seal without remove the cylinder head.. I not going back to garage to find those con man anymore ... :angry:
http://img172.exs.cx/img172/9637/dscn09659da.jpg
hi alantan .. What means of running lean ?? fuel too much ?? or air too much ??
my fuel consumption is a bit high ... I really headache .. so many issues ...
lean is runing to much air...
the combustion chamber is not clean thus it builds up carbon lor....
better seek for beter advice
Check out this link :lol: :P http://g88.fotopic.net/p11155144.html
:) Thanks alantan and g88 ...
By the way .. if running lean .. which screw should i adjust ??
Air fuel mixture screw ??
My car is wira 1.3 converted to 1.5's block .. without RPM meter .. jiat lat .. no RPM meter for reference :P .. can i just listen to the engine idle ? when do tuning ??
Originally posted by ocean+Mar 9 2005, 21:04 -->
QUOTE (ocean @ Mar 9 2005, 21:04 )
--QuoteBegin-alantan
@Mar 9 2005, 20:53
:( [/b][/quote]
to answer your question abt spark plug check this website out
http://www.centuryperformance.com/spark2.asp
u got a leaking prob in ur engine B)
hi g88 .. the website you gave provide very useful information .. That is your own website right? Cool .. anywhere ... do you know the right site of carb if view from inside the car (like the picture below) .. the blue and red color screw .. what these screw's function? Foreman adjusted it before .. was thinking want to set it back to factory default setting ...
http://img146.exs.cx/img146/4925/dscn07371ec.jpg
Originally posted by cookie+Mar 10 2005, 09:18 -->
QUOTE (cookie @ Mar 10 2005, 09:18 )
@Mar 9 2005, 20:53
u got a leaking prob in ur engine B) [/b][/quote]
Thanks ..
:unsure: compared already ..
but not sure is "Carbon Fouled" or "Oil Fouled" ...
what do you think ???
:blink:
if yiou're tuning your idle w/o rpm..
listen to the sound and feels the vibration of the engine
Originally posted by ocean+Mar 10 2005, 10:18 -->
QUOTE (ocean @ Mar 10 2005, 10:18 )
@Mar 9 2005, 20:53
Thanks ..
:blink: [/b][/quote]
if it is dry looking then carbon :lol:
if wet then oil :ph34r:
Originally posted by cookie+Mar 10 2005, 11:03 -->
QUOTE (cookie @ Mar 10 2005, 11:03 )
@Mar 9 2005, 20:53
Thanks ..
:blink:
if wet then oil :ph34r: [/b][/quote]
Got oil around .. Should be "Oil Fouled" .. Last time when i drove back to penang on highway .. My car engine overheat before .. The tempeture needle almost reach red .. but I just slowly drive 80 KM/H all the way ... anywhere .. when reach hometown .. i immediate go to my hometown garage for checking .. found the radiator dirty and wash it .. after that changed the head gasket also ... The mechanic told me piston ring still can be used .. change gasket enough already .. OK lo.. since you told me like that .. but the problem start after this ... day after day .. ceng ceng ceng .. start eating oil ... bo chap .. used for almost 1 year.. situation getting worse ...
Last 6 months ... sent to JB's garage to do top overhaul .. that BTC foreman told me .. don't worry .. change piston ring and valve seal .. confirmed will solve your problem .. when he opened out cylinder head and pistons .. I went there to see .. I asked him .. Does the cylinder walls OK ?? need to bore ?? He told me .. No need ... no problem one .. If need to bore .. I will tell you .. Your cylinder walls OK .. He used his finger goto touch the cylinder walls .. See .. so smooth .. :unsure: Can we use our finger to feel the cylinder wall worn or not meh ??? 3 days kaw tiam .. I went to take car .. drive for one month .. notice the problem didn't solve at all ... The problem is still there ..
Now i believe It should be cylinder walls worn ... Not going to repair anymore .. Going to upgrade engine soon .. Will use this old junk until pecah ..
Hi all, currently my ride is 4G15P Carb... can i gain any HP by using this stock carb? how much HP i can gain if i use webber carb? hope you guys can help... thanks :P
aaa...me also carb user..
fred..i think u shud plan the tt at least 1 or 2 weeks earlier laa...then the people here can arrange their time to tt...
jus my 2 cents
my car std tapi slow bai B)
i oso drive carbie! iswara 1.3
but i'm in JB,no hope for TT http://messenger.msn.com/MMM2005-02-03_09.26/Resource/emoticons/cry_smile.gif
uncle fred..jus want to know..
hav u upgred ur braking system??
what about ur clutch and flywheel?..r they still std?
