carburetor : 4g32 jdm twin carb
arsenalboi
any way to improve fuel consumption? now running 4g32 twin carb each with individual knn filter. any info appreciated.
had you serviced your carb recently? basically when the FC increases on a carb its usually tuning or the filter is dirty which makes you step more on the paddle to make the car move thus resulting in higher FC...
filter i cleaned the twin knn.all i need is for someone to balance the carbs cos the pressure for all 4 intakes is different and resulting in my spark plugs dying very fast.
balance carb huh? okie that one simple, first you turn off your engine, get your carb tuning allen key and close the AFR screw all the way then open two rounds, maark the allen key when its full lock and turn two rounds from there, each carb do the same... then later after that tune from there, make sure the idling screw is also adjusted once the two screws had been unscrewd 2 rounds.....
then adjust from there, watch for irragular idling and also the sound of each carb intake... you can tell from there wan :D
is it ur car model is colt galant sigma??????
coz i owned the model is mit. colt galant SL 1977 (sedan) runs wit same engine tat u mention is 4G32 Saturn Engine,Solex carb......but my fuel consumption cant adjust just like u mention........
Please Help... I have a 4G32 engine which is changed from 4th gear now its until 4 gear transmission..
How many Km/L will it consume now? Anyone please help
