yesterday i set it with the vacum hose connected around 2.7bar. Then go test the car. but ho...i open the hood n check again...the pressure was go down around ~2bar. how come ha????:hmmmm:
then i adjust it back to 2.7bar again. tonight will try again without connect to the solenoid (direct to manifold) for the vacum hose.
it is a normal practice to set the fuel pressure without the vacuum hose connected. btw, did you properly tighten the lock nut at the adjustment screw ?
yups..i saw that also...only the part that i wondering is only around 2bar+ with vacum hose connected. that seem very low..hehhee
but if install this FPR then run away to kl for dyno tune also feel a bit waste..some more the petrol so high now..haiz..y mlc dont have dyno machine....
'(00): Just last Sunday, the streets of Kuala Lumpur trembles with the screaming V8s from the Red Bull F1 piloted by David Coulthard and the ABT R8 LMS driven by Alex Yoong. The temporarily closed up Jalan Bukit...
