Automatic Transmission
amirol
hey.. just wanna to ask about this question..
why can't we push start an automatic transmission car?
cannot isit...who told u...its just the ignition wad....nvm free bump for u hope some sifu's have the aanswer...lol im also runnin auto tranny !!!
Good questions, why lea? My theory:
Manual tranny is connected to the engine directly with the clutch plate, so it can also be improvised as a manual starter. Like the crank starter in most pre-WW2 car, those cranker in front of the engine outside the car. You crank, engine move, dynamo make electricity, then engine spark, VWRRROOOMM.
Automatic tranny is shift by using hydraulic in the gearbox, so basically when you push to a petrol station far far away (30km max) or attempt to push-start your car (not gonna work), it only running the hydraulic system, and the car won't let you start at "D" position, "N" position acts like the free gear in manual, so you're actually damaging your gearbox little by little. That's why car towing is best when using flat bed tow truck (ie the car's all 4 wheels is on the truck, not rolling on the ground) or using the "free" wheel (ie wheels are not driven by the engine). Conclusion, better call in a tow truck rather push-start it. That's why an automatic tranny can be troublesome in some cases, and expensive to maintain.
good answer there by tk2005takeru, not just a theory. that's the truth.
anybody driving an auto car without a jumper cable - he's just nuts
oohh.. i see.i've asking my self since last year.. manual can be done.. but in auto..huh.. thanx :regular_smile:
If no jumper cable, use hands and feet to connect the 2 batteries and get the jolt of your life. Haha!!
can i ask something about car batery?.. when discharge of a lead acid battery, the active material is charged to... :confused_smile:
