- Joined
- Nov 16, 2005
- Messages
- 251
- Points
- 1,516
Anyone have experience built in the vitara ABS in swift. If not, do you have any idea , how to make it.:sad_smile:
ABV9750 said:personal opinion..
any peformance car require a superb braking system. abs nowdays is a compulsory but as technology goes, EBD, ESP, ESP2, traction control has been equip.
as a basic braking, when apply certain brake pressure, front brake will firstly lock..then fully depress the braking pedal, higher amount of brake pressure will lock the rear thus all tyre lock.this would be very dangerous during wet road condition.
to overcome this, abs is required.
for gti, i don't see anyone has successfully moded this but for sure, track car should have.
for syafique, you may do an experiments using aftermarket abs. this is cheap and easier to install rather than a vitara.
if you look at all scooter motorcycle, they have it. its a simple mechanical abs.try it at all brake..maybe good mechanic shall advice more in details.cause you need to calculate the brake efficiency by considering the fluid pressure,flow and heat to avoid a broken hose and jammed.
good luck.
me drive slowly..
)??? Been interested in this MR2s since I was a kid... hehehe...
