Where do you do Allignment for your CL7?
sPoOn3838
to all sifu here, i just got my cl7, and cannot find a shop to allignment my car. because system dont have my car spec! Where can i do allignment? i am at puchong area! thankQ
The facory specs will be similar to local accords.
Well if you want better handling response you can change the setting without affecting tires wears.
kian long opposite gt auro in sunway. ah lun
found this when I was surfing the net last time. Not sure correct or not?? :confused:
Stock CL7R Alignment
Camber :
Front : 0deg +/- 45'
Rear : -1deg +/-30'
Castor : Front : 3 deg +/- 45'
Toe in (total) : Front :0mm +/- 2mm
Rear :2mm +/-2mm
Front turning : Inside : 38deg50' +/-2deg
Outside : 31 deg 40' as reference.
Thanks bro will go this week!
---------- Post added at 11:51 PM ---------- 6 hour anti-bump limit - Previous post was at 11:16 PM ----------
Camber :
Rear : -1deg +/-30'
Rear :2mm +/-2mm
drop down now!
Sudu3838,
Mana2 kedai alignment got the spec for CL7.
The only thing that you should worry is your chamber.
