Max Speed Of Ur Myvi!!
Lolz! Which of your car are you referring bro ST? 218km/h is scary man..u r really brave :adore:
TitanRev: 2.0Bar possible bo :rofl: and Myvi can put why Altis can't put leh? More power also lolz!
I think yeehau86's Altis can...2ZZ-GTE. :rofl: :evil:
I agree with you, TR and ST. Picture time.
Pictures speaks louder than words, or come to Kepong TT for Supra Fanatics to inspect. :evil:
maybe he ask his other 3 passengers in the car to help him blow leh? maybe is more than 1.8 bar... their blood pressure la... :biggrin:
Lolz! Maybe a Mini T04Z gua...lolz! Maybe a latest version one leh...as small as a K&N Air Filter :rofl:
That's the only reason it can fit in...:rofl:
I dunno much about Turbo thing lar...still damn noob in NA lolz!
YH, I want to see the engine...sure very kau....if don't have pictures also nevermind.....just tell me the mod spec...
Injector CC: ??
Running wastegate: Yes, No
Wastegate size: ??
Fuel pump: ?? lph/hr
IC size: ?? inch
Brakes: ??
management: ??
Boost-in: ??
Max hp : ?? at how many RPM
Max Tq: ?? at how many RPM
Throttle body size: ??
Your T04Z housing is T4 divided or T4 undivided? or T3 4 bolt?? AR value?
Thanks for the info angler D5..
No, mizunori. I think the driver himself blow water 1.8 bar, not the engine.
---------- Post added at 03:04 PM ---------- 6 hour anti-bump limit - Previous post was at 02:35 PM ----------
please reply the inquiry above by TR, thank you in advance, angle-d5
ST - i think you crank the engine also i get heart attack edi...
Wah~~ST.....you're the god....I bet the thrust from the quad is more powerful than A380 during lift off....
Nyahaha. Maybe the chassis can even cabut from the engine and drivetrain. :P
Btw, obvious that angle-d5 is just all talk la.
huh? can joking or not ga? :biggrin:
entertain har la woi!
nothing to said nothing to laugh
i very not happy la!!
tam har me can or not?
very funny wei, H-A-H-A~
but still, can you list down what TitanRev required?
Injector CC: ??
Wastegate size: ??
IC size: ?? inch
Brakes: ??
management: ??
Boost-in: ??
---------- Post added at 06:57 PM ---------- 6 hour anti-bump limit - Previous post was at 06:44 PM ----------
why not happy? because we managed to find out that what you talk is just TKSS?
next time when you want to joke, do more R&D..Here got a lot of sifus in automotive, you won't be able to trick them..
I give you 1 hour to proof what you said. Start from now 7:14pm
i miss something very interesting here.......... :rofl:
just start lepak here......
Engine model-(K3-VET)
Max.power-(Net), kw(PS)/rpm 140 ps (102.97 kw) / 6400 rpm
Max.torque-(Net), N*m(kg*m)/rpm 18.0 kg*m (176.52 N*m) / 3200 rpm
Power density 6.71
Engine type Water cooling serial 4 cylinder DOHC16 valve IC turbo
Engine information Horizontal ranging DVVT
Fuel system EFI (electronic fuel injection)
Turbocharger Turbo with intercooler
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 72
Stroke, mm 79.7
Boost 0.8bar
Upcoming upgrades will be AFC... Disc brakes...
YRV Steering with +- shifting knobs...
spending around 9k++
Power density 6.71
Bore, mm 72
Stroke, mm 79.7
Boost 0.8bar
I don't think you are answering TitanRev's question, nice plagiarism (copy paste) you got there from those selling car threads..
here is the correct format, please fill in the info:
Injector CC: ??
Wastegate size: ??
IC size: ?? inch
Brakes: ??
management: ??
Boost-in: ??
Power density 6.71
Bore, mm 72
Stroke, mm 79.7
Boost 0.8bar
Eh~~not 2 bar meh?? where's the T04Z? Please this is info for stock car lah....
So what you said earlier was all BS??
New Posts
