Need an advice:Vibration when > 120 km/h
ALiAS
298
23
Guys
Need help.. my Altezza while driving + 120 km/h the steering gegar and feel very lite... and the best part is, the vibration only come while driving in rain / on wet road... while on dry road, can go faster without any prob...no vibration...
so went to our Altezza taikor workshop, been told that the prob is with my alligment & balancing...ok... that day itself went to do the alligment & balancing... after everything's done it started to rain... so try to drive + 120 km/h.. and the same thing happend...
went to another Altezza taikor workshop, they also tell me the same thing... thinking of the 1st tyre shop staff maybe did not do the job well, so try to do it again my balancing & alligment at another tyre shop.. yet after that same thing happend... and its become worse when TRC off...
currently using 18" and using MICHELIN Pilot Preceda... the tyre just use about 5-6 mnths only and i only drive my altezza during weekends most of the time...
so any idea...? kering idea sudah...
1JZtezza
371
42
Re: Need an advise: Gegar when > 120 km/h
steering light can be so many things...hydroplaning,toe-out,+ve camber.
Others....suspension,bushings,ball-joints and/or lower arm.
hope this helps.
wfhan
4,339
96
selangor
hope this helps.
my bet is on bushings & ball-joints.
TRDtezza
64
1,508
Sabah
you should check your rim... most of the time , low speed vibration comes from the rim itself. If one of your rims (front ones) has a dent or balancing weights is gone you might experience low speed vibrations and it will be gone at high speed... you better do a check as this might damage the bushings as well...
Greytezza
1,130
68
1,648
Truly Asia
TRDtezza... Alias is saying that he experience the vibration at 120km/h only during when it is raining. It has nothing to do with low speed vibration dude.
TRDtezza
64
1,508
Sabah
whoops.. i guess read something and the brain took something else.. Well , after reading it carefully i don't really know what is wrong. dry and wet surfaces has just got to be the tyres itself then , as its the only thing that contacts the road... I don't think any other part of the car will create any difference in tropical climates.. check the tyres maybe @@
G221
Over 10,000 RPM!
13,344
61
yes..might be caused by the uneven tyres (bunga tak rata or makan dalam). Happened to me b4..normal driving was ok..when reached 90-100km/h...car, steering start vibrating..when reached 110-120....180km/h no vibrates. changed both front tyres..problem solved.
TRDtezza
64
1,508
Sabah
G221 , he was mentioning about wet and dry road condition , not speed.. ( why does this sound to familiar)
G221
Over 10,000 RPM!
13,344
61
TRDtezza, yup...he was mentioning about the prob when in wet condition. I was explaining my prob happened when in wet and dry..so won't be no harm if look at the condition of the tyres and change both the front tyres. :idea:
1JZtezza
371
42
we are all trying to second guess!
Perhaps bro alias could elaborate what changes apart from the tyres and rims.ie whether it just happened becoz of wear and tear or becoz of change tyres and rims.
ALiAS
298
23
guys...
thanks for the advices..
tyre (MICHELIN Pilot Preceda) - checked with the tyre shop.. bunga everything ok... the condition is still good... the rear tyres a bit older than the front, but i think that doesnt caused that vibration etc as the tyres also are still in good condition... maybe another 20k ++ km only need to change it...
rim sukan (Gram Light) - if balancing ok means the rim is also ok rite...?
bush - just changed to TRD bushing 2 mnths back at our taikor workshop... changed together with another standard lower arm there as the bush comes with it..
driveshaft????
and also no mod on whatever related to handling...everything is stock...
aiyooo... pening...
nway will go again to our taikor workshop and let you all know the result... maybe by end of this weekend...
TRDtezza
64
1,508
Sabah
did you check for the any uneven places of the threads? I'm previously using preceda as well , soft but the threads tend be uneven soon after a month... i experience noise first , but then i changed it ...not sure if it will lead to any vibration .
1JZtezza
371
42
methinks it could be bush and lower arm
green
326
25
3,028
kl
alias, try going to alex's place in bandar tasik selatan. perhaps he can help you.
one way of doing it is loosen all ur suspension links...meaning to loosen all the nuts n bolts n drive around slowly, then retighten. this might help.
this guy is ex-rally driver so he can probably help you out. he can also have a look at ur car
cheers
alex 0192642539
u no choice lo, everything also gotta try out lo
ALiAS
298
23
just change the new one wooo...
cheers
alex 0192642539
thanks Green... will call him... mind teman me go there hehehe shy le... :biggrin: only monster-ed altezza there... mine standard gaban...
anthenna
126
5
Is it possible the new bush's prob? Change d only happen?
But mostly the lower arm prob. Experienced before but for another car. Try that.
green
326
25
3,028
kl
theres nothing to be shy about. you are after all a customer to him.
just go look for him. I would say he is very knowledgeable in cars especially the altezza after so many transplants.
like i said, everything u also need to try lo.
good luck
original rare spec Rays Volk Racing CE28 18x8.5 18x9.5 5H pcd 5x120 Lightweight FORGED rim made in Japan
original rare Rays Volk Racing CE28SL 18x9jj offset +48 5H pcd 5x120 Lightweight FORGED rim made in Japan
original rare Enkei RPF1 19x8.5jj offset +35 5H pcd 5x120 Lightweight rim made in Japan
original Yokohama ADVAN Racing RG4 18x9jj offset +53 5H pcd 5x120 Lightweight rim made in Japan
BRAND NEW original TRUST GReddy 12004607 Universal Oil Cooler Kit Standard Type 13 Layer made in Japan
original rare Rays Volk Racing TE37 18x8.5 18x9.5 offset +40 5H pcd 5x120 Lightweight FORGED rim made in Japan
Rays TE37 Saga S Plus Civic Type R FK8 TypeR PCD120
original rare Rays Volk Racing RE30 18x8.5 18x9.5 offset +35 5H pcd 5x120 Lightweight FORGED rim made in Japan
original rare Rays Volk Racing Gram Lights 57CR 19x9.5jj offset +45 5H pcd 5x120 rim made in Japan
original rare Yokohama ADVAN Racing RS 19x8.5 19x9.5 5H pcd 5x120 Lightweight rim made in Japan
original rare Yokohama ADVAN Racing TC4 18x9.5jj offset +45 5H pcd 5x120 rim made in Japan
original rare Enkei GTC01 20x8.5jj offset +43 5H pcd 5x120 Lightweight rim made in Japan
original rare Rays Volk Racing CE28 18x8jj offset +38 5H pcd 5x120 Lightweight FORGED rim made in Japan
original rare Rays Volk Racing CE28 18x8jj offset +40 5H pcd 5x120 Lightweight FORGED rim made in Japan
Rays G025 19x9.5j +44 FK8 FL5 Type R Rim PCD120
A Post Every 5 Mins
hey guys, im like totally new here, well just wanna have some ideas, i got my new wira, but i thought of getting a new exhaust or muffler, well thought u guys can help out and suggest some pics, i dont know which exhaust will look nice. =/ stock proton but added a lil of skirting, black paint job =)
Bump:
