The best security for your car!!!
u can install another alarm unit to control fuel cut. control by using remote control.
install a normal alarm system. using the alarm active ground(-) signal output(grey wire) to connect to a relay. using a relay to turn ground(-) output to positive output(+). connect tis output(+) to original fuel pump relay wire.
went alarm is activate, fuel pump is active too. wen wen alarm is deactivate, pump is not in function.using LED as indicator.
Nice one.. never thought of using another alarm system to control the fuel pump relay.:top:
some how, we need to follow what Mr Bean do to his car... put door lock at car door, then 'quick release' the steering whenever get out from car.. put into beg. make sure ur beg big enough to put 'Nardi limited' or 'E3 momo 3 spoke' inside.. hehe..
....thank you for sharing ! I'm a car thief, you make my life easier, keep on posting:thefinger:
New Posts
