7AGE conversion
scottwrx
guys, juz sharing the project of 7AGE, as i juz got my car today after 3 long weeks... thank to bro howard for letting go a lot of stuff, that let me save time and money.. thanx a lot bro.. drinks on me next month!!
i will answer the pm that was sent to me
1. timing belt, using Porche 924, my other fren use peugeot 406, about RM500 to RM700
2. con rod & crank shaft ...use back 7AFE ...
3. head use back 4AGE 20V, piston use bt, same bore juzt longer stroke
4. use full top set including gasket for 4AGE 20v
5. exhaust cam pully need to change to adjustable, maintain vvt for intake ( this one just try only, coz the setting is still not accurate, if cant then need to change to adjustable intake cam pulley
6. fuel pump ..walbro ?? or using evo 8 de ...
fuel pump change to evo3, injector change to 1j
7. water piping jus alter a bit
8. i also did engine balancing and lightened, for better respond at hi-rev, after run in will try hi rev n let u all know
9. engine mounting is the same as 4aGE ??
10. aircon mounting need to modify, coz if use back 7a oil sump, it would block the belt tensioner bearing
11. and need to make a custom extractor, due to taller block..
total money spent
block 700
crank balancing n lightened 1200
top set 450
piston ring 190
1 j injector 500 - excluding mod
evo pump 150 - trade in - this one brother price lah...
labour 1000
extractor 500 ( estimate)
timing belt 700 (estimate)
and other zapalang stuff 500
i will update you guys after tuning, run in n dyno lah.. now damn fxxking poor already..
already edit on the price, coz some price is not accurate, this is the brothers' price that i m getting.. hehehe.....
Poor nevermind ma.... power enough liaw.:thefinger:. Interested to know the end results also.
lol~~~
poor wat la?
u get wat u pay!
some more monster coming out liao!
hahahaha:P
yeah.. waiting for the result. with dyno is better. hahaha.. compare it with stock meh...
so bro nothing to upgrade already......
and can see the GTR 35 or EVO 10 tail light already.....:driver:
nolah.. juz sharing, coz i wanna to drive n car with a higher torque... if this project is a success then can share with other fellow members mah... but seriously when i starter the project, everybody say no hi rev... i am really waiting for the outcome.. hehehe.....
Well done bro with still keeping in NA category. If me... I might go for Supercharge or Turbo charger already... LOLzzz
haha..scott have ENDLESS money oh...
damn envy u la...scott...
when borrow ur ride jek?
let me rape 1st..haha!!
Block??
Timing belt anyone try 3SG(if possible prefer toyota for toyota)
Hope you use the BT oil pump or a TRD one!
VVT for intake cam only.......why need adjustable(cam pulley) for exhaust cam if standard???
endless your head lah!!!! KNN rape cannot lah.. still run in.. i "fong sui " you 5500rpm how??? muahahahaha... juz yesterday tested with a standard bt, par if i shift at 5500rpm..coz running in mah...
---------- Post added at 09:49 PM ---------- Previous post was at 09:47 PM ----------
Block??
i dun think 3sg belt can be used lah.. coz 7a block is much taller than 4a, i will check the 3sg spec.. thanx for suggesting anyway, i m using adjustable exhaust cam pulley and vvt pulley... might try adjustable intake in the future...
3SG confirm not gam with 7AGE!
lol..1.8 bully 1.6 la?
my 1.6 eating ubi now, how to test leh? wakakka!!
plus i'm planning to put in 3SGTE next year..that time i can find u challenge jor...wahahahaha!!!
now i got 2 options
1. continue JDM
2. give up JDM go for performance
dunno which 1 is my last choice leh? but for sure now is for the JDM..hehe!!
now i got 2 options
1. continue JDM
haiyoh.. you car damn fast also lah... no bully you one.. if u wan more power do like sarip lah.. 4AGTE, u jdm king, sure can find a complete engine with blitz n management... then can bantai b16b kau kau already lah!!
build the monster to bantai B16B? ermm... i don't think it is good ideal kua... Since BT with light mod can eat B16B stock very easily only.
Boss, after run in, come come test with me .. i want to see how far i kena from your monster. Eager to kay poh lor .. lolx.. and no need to fong shui me .. keke
I buy you TGI Fridays b4 the run , ai mai ?
wow, penang people very best la, test2. here in kl, test2 if kalah macam2 alasan.
vacuum tercabut la, berapa ribu $$$ sudah invested la... if menang, will say ' tak payah mod banyak2, tweak here and there, sudah menang with kereta byk barang'..... haih, people with their mind.....
hehe.. test can lah.. but make it between u n me lah.. dun wan spread spread... your car also damn kau fast already... may be i kena from you leh??
SVT dragging a 205 tires, no need to worry la. NA vs NA won't be far off the scale.. 22nd you got go?
