How to calculate compression Ratio?
EG9
Subang Jaya
Guy, I need your help on this.
May I know anyone know how to calculate CR for this setup: 7AGE 16V.
Engine Head from: 4AGE 16V Small port
Engine Block: 7AFE
Piston from 4AGE 20V (AE111)-Blacktop.
0.5mm metal head gasket will be used on this setup, may I know what is the compression ratio for this setup. Thanks!
Some of the guys from Club4ag.com feedback that this setup will be 14:1 CR. Which is very high. Headeach on this.
thicker head gasket?
use 16v small port piston??
that shud drop it around 12:1??
well i dunno....just guess hehehee
just put in that comp test meter laa ... then compare it with another engine which the CR u already know .. this method of coz not 100% accurate la .. but close enuff liauu ... :p
I don't think it's 14:1 compression ratio.
Although I have the formula to calculate the CR, but I don't have some value needed to add in for those calculation.
Normal 7AGE 16V setup that I read from other country forum is using 4AGE 16V head and piston only have 9:1 CR. (and they are using 0.5mm metal head gasket as well)
The only different stuff in my setup is blacktop 20V piston. Will it jump up to 14:1 CR? I doubt it.
who have comp test meter?
can borrow? hehe
Compression ratio is best calculated when the engine is disassembled.Roughly,calculate the swept volume+deck+chamber volume and divide by chamber volume.I think 7AG should be around 10 CR since the G type chamber volume slightly larger than F type chamber.Compression meter cannot use to measure CR,not accurate.
my 2 cents
then...
use the comp test meter...
crank for...let say 3-4 times...
n then get the average reading ler...
unless if chu's engine already on the floor...
my 2 cents
When u came back?
So my setup should not be more then 12.5:1 CR?
7AFE block, Blacktop piston, 4AGE 16V small port, blacktop piston.
CHu,just come back about a week,after that straight go to work,then weekend busy with sic drag,sorry didnt call u,already here now,might need your help also..
Blacktop piston,hmm..i dont think will be more than 12.5 also,maybe 11.5-12
Write your reply...
