Bo SEG
hye there...here i have something to ask...
i want to top overhaul my engine BT 20v...should i skim the head to increase the compression?....i got 0.5mm metal head gasket...so it will improve the tork ryte?..
some of my source tell me that SVT head much better than BT based on its "kawah"...so is it good if i mix BT engine with SVT head?....any comment....can i use BT camshaft on SVT head?...how bout the compression?...do the ext hole need to bore coz the BT more big than SVT?....how bout the MAP sensor...??/....how bout the intake?...
which one better to made improvement on my BT w/o change camshaft....
i want to do mixing for performance which its low cost than put aftermarket performance part...
any idea on HEAD modification for performance?
