BT 20v + 7AG
norm: it's common la nowadays.. but back in year 99.. i remember in kl got 2 only...1 plant potato... 1 was mine..which was running very well :)
simple setup... no apa lanjiao management... jes S-AFC (5 buttons) to control the main injectors and an ERL MF2 to control 2x HKS 550cc injectors...
welcome to 7AG group .
wondering 20v cam gear is same as 16v or not. porsche 944 belt is 117 teeth, on 7AG will be little longer i mod the idle pully to make it fit. run 4 years 7AG turbo already engine still good good, now going for 24psi for borneo drag. last year is 18psi get 13.2sec .
what u waiting for ? go for it. 7AG
im thinking swap in a 7AF block to upgrade my BT... wat do u think n how much hp could it gain? 20v BT wit 7AF block... hopefully can to get 14.++ sec~ :X-: is that possible?
n/a 1.8 with stock BT head, high 14sec might be can la.. it is not easy for a stock chasis to do so.. i done mid 14sec with 7AG turbo gze ecu 1bar boost on stock chasis..
last year i had done drag race ladder bars, with 18psi and microtech ecu making 13.2sec.
good luck..
new intercooler just installed to handle higher boost, done new rear chasis frame.
http://www.boomspeed.com/levinte27/DragCar.JPG
u might getting around 10% hp gain. :)
then is the 7af block easy to get? and how much is the block?
not easy to get. used to be very cheap but not now anymore. i do know a friend of mine in spore wanna sell his block only for sgd450. siao...
scomatic said:
tested before the 5AGE? haha:_:
this 5A i oso never see b4 .. i would oso like to know if anybody has this mod ... at the same time i might as well ask if anybody tested formula atlantic 4AGE b4 laa .. hahahahaahaa
The concept of increasing the stroke to gain displacement in a gasoline engine is an old trick. Nevertheless, it is still a very effective form of tuning today and the 4A-GE is no exception. In the late 80’s, HKS developed a conversion kit consisting of longer stroke crank and pistons for the 4A-GE. The line has been expanded to array of configurations, which range from 8.0-11.6 in compression rates. This kit was called appropriately, the 5A-GE kit.
Once a very popular mechanical tuning approach to the 4A-GE engine, the 5A-GE engines proved that more torque could be had in the otherwise peaky nature of the 4A-GE. It wasn’t without demerits but the 5A-GE did fare reasonably well in the enthusiast market. HKS makes a range of internal components to suit your needs and 5A-GE was one of them. The 11.6 compression kit comprised of longer stroke crank, 81.5mm pistons and various bearings, rings and fastener sets is the most aggressive. They are designed to be built using the 4A-GE and proved to be very high quality in design and materials. However, the 5A-GE isn’t without pitfalls so we’ll discuss a few here in detail.
The first thing we must note in the 5A conversions is the fact that the block needs to be modified somewhat to make room for the longer stroke crankshaft. The 5A-GE kit uses this long crank stroke to make approximately 1700cc displacement but slapping this crankshaft into the 4A block; one will immediately discover that it won’t spin without hitting something. No, it’s not a defective unit… So we modify the block by grinding away the inside of the crank case…. by placing the crank and working away where it hits. The clearance here should be no less then 1mm so you can avoid damage when there’s engine failure elsewhere. Next, attach connecting rods and repeat procedure. One note here…never grind the rod or crank as this will upset the balance and strength of the moving pieces…unless you are doing it for the purpose of getting better balance.
Second step, and the one most people forget, is the dynamic balancing of the crankshaft. Although the finish and materials is top notch when using HKS, the problem still lies in that the crank is longer in stroke. Often, the crank has worse balance than the 4A-GE unit that you took out, which is a real problem on an engine you plan to take to 7200rpm and beyond. An incorrectly balanced shaft can rob you of power beyond 7000rpm and more at higher rpm due to the inconsistent cylinder pressure and piston timing. Not to mention a myriad of failures it may induce in all sorts of places. The crank takes about 4 tons of force every stroke so think of it as being very flexible, contrary to how it may look when stationary. Balance, balance, balance…
Next, always use pistons designed for the 5A-GE or similar stroked crank. The 5A-GE pistons have a different piston-pin height, therefore cannot be crossed over. Furthermore, the block to be used should be as late model as possible. The 4A-GE, as we all know bay now, went through many production design phases and with each iteration the performance potential increased in terms of strength and heat resistance and dissipation. Not all 4A blocks are equal!
Lastly, most important perhaps, the 5A-GE is an expensive and labor-intensive modification. So, its final outcome is whatever you put into it. Taking time and some careful planning of funds and components will give you a strong, high torque rating engine that’s as free revving as your 4A-GE. But shortcuts will cost heavily and the final product will just as easily be rough and unwilling to perform.
*take from Club4AG website
toyoae111 said:
how?? really can make it done? :X-: if really...i want~~~~
cannot la.. bro... The 3S is 16 V... How to bolt in 20V? if 16V also, need to bolt the block, and too much afford. Rod also can't matching. and 3S engine damn costy... unless the rich guy can hybrid it...
yalaa .. i have heard of this 5A mod b4 .. but never see with my real eyes or even heard of anybody here that actually did it laa .. 7A +20v i have already seen and driven laa .. stroking the engine to increase capacity and "power" i already know more than 10 yrs ago .. no need to cut and paste .. :p hehheheheee ...
asking about 5A is almost the same as asking about formula atlantic laaa .. $$$$$$$$$$$$$$$$$$$$$$$ .... not many or almost nobody here does it one laaa
:_: 3s block cant match in 20v.... thats the limit 7a block into 20v..... just wonder how much power can it gain by using 7a block into 20v..... :X-: really cant wait to hybrid them as soon as possible..... :X-:
