hmm... will it give any negative side effect to the block, ie crack etc... if we bore the intake and put bigger turbo, plus bore the exhaust manifold? i mean can the standard 4g93p take such massive load?
dont forget to change piston and rod
td05 small 16g mated with 6cm turbine housing, umph on 1.8 gsr
had done some of part add on from evo to my 4g93 such as wiring, injectors and air flow sensor. also dump in e manage complete with ignition harness and injector harness as well. the result, smooth ride, but still a little high fuel consumption.
Bump: had done some of part add on from evo to my 4g93 such as wiring, injectors and air flow sensor. also dump in e manage complete with ignition harness and injector harness as well. the result, smooth ride, but still a little high fuel consumption.
oh i see... some people told me that the wiring is very much different... now only i know... but too late already... nevermind lor... maybe later when have money, i will change the injector to vr4. will that help?
