Opinions of GAB HA series height adjustable suspension
from my opinion...find GAB fr Japan....u will satisfy....
GAB which available here im not sure....could be recond set......
How exactly can you get new Japan GAB now?
It's all newly manufacturer in Malaysia. All of them except the SS Series.
what is the piston diameter of the SS series compare to others? i got to know the bigger diameter allows better damping. is it true?
bigger piston can dissipate heat better too.bigger piston=better damping,it's true.
reason,forgot....hehehe...try google it up star scream.i've read the article before.
there a good reason why all adj sus manufacturer racing to make their piston
bigger.the biggest that i've heard of if i'm not mistaken is a round 48-52mm.
don't shoot me if i'm wrong.tend to forget a lot of car tech lately.hehehe.....:rofl:
I went to kakimotor in sunway and the sales person recommend me the zerone adjustable claiming a bigger pistons for more precise damping, then i went to 1 utama shopping center and saw the pedders absorboers claming a 52 mm diameter pistons for better performance. So im just wondering and pop out this question.
big doesn't mean it's good.sometimes the design that made the abs perform well.
there's other factor that need to take into consideration in making a good set of
abs.
abs.
Totally agree. The material grade use on springs, shafts, housing & etc, Inverted monotube design & the most significant, production QC. Impurities in the gas/liquid filled chamber might also effect the overall performance.
gab ss series selling at rm2200 now
Front full adjustable shock absorber x2 (with spring)
Rear full adjustable shock absorber x2 (with spring)
Height adjustment special tool x2
Damping force adjustment special too x4
Front pillow ball mount x2
got one seller told me
maybe it would be better to get this one
my hks and bddyclb all out d
Write your reply...
