GAB SP Series (Cool Sport Lowered Spring) Lowered ride, Cool stylish, Better handling, Comfort.
- Enhance the response speed
- Greater road stability, which gives higher turning speed
- Reduces body roll & braking distance for more safety
- Superb handling and stability on highways and cornering
- Sporty look and comfortable
Advance Technology Cold Forming
In contrast to hot forming where the spring is coiled at an elevated temperature, springs of our series are made through the technique of cold forming (normal temperature forming at a non elevated temperature). By using a dedicated new-type coiling machine, deterioration of the material is prevented and advance performance is retained.
Made of SAE 9254 Steel
Tested by over 500,000 times, compression inspection deformation less then 5% high strength sophisticated surface dealing, durability was highly improved.
*All products series of |G|A|B| come with 6 month or 1 year warranty. To satisfy our customers
Rm250.00-600.00
GAB SA Series (Heavy Duty Sport Absorber) Extra long life span, Better handling, Comfort, Reliable, AVCS.
Satisfaction guaranteed with handling improvement & comfort
SA series is well balance heavy-duty sport absorber, Auto Valve Control Stability (AVCS) has the ability to be more effectively absorb the impact and vibration from uneven road condition, and provide maximum grip and traction. Superb handling, high stability and comfortable is SA series successful point.
Compatible with all type spring
Unlike standard shock absorber, SA series sport absorber can compatible with standard spring or sport-lowered spring with out sacrificing ride comfort and absorber’s life span.
Lower price & affordable
Auto Valve Control Stability (AVCS), high-pressure nitrogen gas fill in, strengthen absorber structure, double up life span, all this great feature came with reasonable price
Rm500.00-1000.00
GAB HA Series (Winding Road Height Adjustable Coilovers) Front & rear height adjustable, Maximum grip and traction, Superb handling, High quality & performance, AVCS.
The BEST height adjustable shock absorber for the Beginner
Bumpiness and roughness are eliminated as much as possible and persistent setting that gives moderate rolling speed at cornering is achieved, to fit any winding road or any streets in the whole wide world.
Full height adjustable with Auto Valve Control Stability (AVCS)
The spring rate and damping force are set to minimize the sense of incongruity when changed from OEM components, so that everyone, including all the passengers, can enjoy sporty driving with NO discomfort. Also, simple adjustment systems, which are ride height adjustment function by seat positioning, make it very easy for anyone to handle.
Thread type height adjustment system
We have adopted thread type ride height adjustment system, with proper case length. Also, threads are coated with chrome plating, which has superior rustproof performance.
Auto Valve Control System
AVCS is an internal system that adjusts the stiffness of the suspension. It uses multiple layer valve spring to sense the road condition and automatically reduces or increase damping force according to the road condition and your driving style. The result is superior handling and maximum comfort on all road condition without having to manually tune or adjust the absorber.
Rm1500.00-2000.00
GAB SS Series (Super Sport Full Adjustable Coilovers) 2-way independent height adjustable, Damper rate adjustable, Superb handling, Maximum grip and traction, High quality & performance, AVCS.
Top of the line ready for competition sports shock absorber
SS series is the top of the line product among all series; combine up to date advance technology with the past many years of experience on road sport and circuit racing.
Mono-tube structure
Mono-tube shell case is adopted to enable very fine control of the machine and aggressive yet detailed communication with the road surface. It generates and maintains very stable damping force, which even stands the intensive and repeated runs on the circuit, reacting to the tiniest data from the road surface.
Extreme accuracy damping adjustment
For finer settings, total of 32 different kinds of damping force are available, by adding the systems at piston rod. Use of specially shaped needle valve enables linear damping force adjustment at every 32 levels.
2-way independent height adjustment
2-way independent height adjustment system with movable lower bracket has been adopted, which enables the separate adjustment of the ride-height and pre-load.
Rm2000.00-3000.00
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newfor...331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newfor...2721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newfor...s-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
