nope........hi bro's..
is there any significance improvement on the fc and performance when upgraded to injection?
yeap... a little better fuel consumption... more flexible in tuning... better options in modifications...but it is better to use fuel injection right?![]()
wiring, ecu, intake manifold, throttle body, distributor, fuel pump, fuel filter, fuel rail, sensors...
estimate budget needed around rm800 (parts alone) + rm500 (installation)... jz prepare around 1.5k to 2k jz incase other stuff needed to be changed as well...
mine stock standard carbie lorsifo.. seem like research more on tis d... how was urs?![]()
yea... need to twist the knob to adjust the idle rpm....carbie with a twist.....![]()
dun simply spread rumours weh...carb but not stock standard.![]()
hello.. i have a very humble 4519 1994 carbie.,.is it possible for me to convert to fuel injction? what are the things that i need, the overall budget, etc. thanks :proud:
tis is the truth fact mah.. not rumours....![]()
rumours only lah...You said the same thing at SIOC today. Of course, everyone knows your car is no stockie. :P
new engine code created by him i guess....what engine is 4519?? :hmmmm:
typo loh..4g15 actually
sori bro..
nway, how to improve the power aa?
hi-cam
1.6 stroker kit
adj cam pulley
skim off ur flywheel
Similar threads | |
