duno why all these cheapo unusable coolant can be sold to the public?
don't they should have some regulations on this?
i just sent mine to Honda srvice centre and i tell you they did a good job...dunno whether it was them or whether the shop that they sent it too was good...however, i was happy...note that i said "was" happy...drove around for 3 to 4 months when suddenly my needle started behaving like my RPM meter when u accelerate...it just goes up n up n up....opened the radiator cap and to my disgust i saw grease or some kind of oily shit in my radiator...i dunno where it came from..did anybody experience this before?
G.
Have you done a top overhaul before?
if yes, the engine oil have been contaminated the water jacket around cylinder block which is the mechanic didn't flush it from the cooling system. it's based on my experienced before.
For the most effective cooling and heat dissipation use DISTILLED water. RO water is also good. In my case i use filtered water straight from tap which is also good. So long the water is not yellowing from hidden rust particles and mud!
When buying coolant, use Orange or Red colored coolant. I use TOYOTA long life COOLANT RM19 for 1 litre bottle. Prestone DEXcool is even better. But very hard to get.
U should use approximate 50/50 water and coolant.
In this case a normal radiator should be around 4 litres capacity. Mine is 4.5 liters. So i use 2 litres of coolant and 2.5 litres of water. Close enough. So use 2 litres of coolant and 2 litres of water. If u have no idea how many liters ur radiator is. But 2 litres of 1 litre coolant or 2 litre bottle then fill up empty bottle with water and u can know easily.
DON'T USE GREEN CHEAP COOLANT! I will tell u last time i use this it turned my rust to white deposits and that nearly cause blockage in my block! Not to mention busted my radiator cap in the process!
Do not flush your radiator if it is above 10 years old. U need to get a full external radiator flush from shops.
Remember Coolant doens't prevent from overheating. It prevents water from boiling easily that cause air to form and reduce radiator efficiancy.
Change the overflow tank water too!
After filling, run the engine and remember to squeeze the top radiator hose and you can see some trapped air pockets coming out. Run until the radiator water is almost overflowing continiously, then cap it.
Enjoy radiatore comfort. :lol:
means i cant flush my more 20 year old saga.? but its rusty though. inside. i checked the other day.![]()
brand new koyo radiator for R34
