ECU ~ Engine Control Unit
~control the fuel injection of the car, the ignition timing, some kind like that.
i want to modify the original ECU, to make it save, more fuel, if can. not sure how to connect from the car to my laptop(what type is the cable? and the software?) to adjust it.
by the way, i drive original Wira 1.5 manual. thanks.
wira ecu.......... hmm.............. it is read only worr.............
u canot re-program it. but u can add in piggy back ecu like safc vafc and others, got a lot at the market. cost u around Rm1k and above which include dyno tunning also. for apexi safc u can tune urself no need go dyno also can.
i know the piggy back ecu u mention about, but it's expensive...
i think alot about this already. if it is read only, meaning that can copy the setting out,right? what connector type should i use? or use a ROM reader some kind like that stuff?
if really can, i can change the setting and buy a new ROM or other ROM's type that can erasable. then, write new setting into it.
are this possible? thanks.
