- Joined
- Dec 31, 2005
- Messages
- 671
- Points
- 1,518
Hi , may i know what is the difference for both semi oil??
ok...mayb ill recommand 6100 15w50???10w40 scared the engine oil will less since u say is a high rev engine..wat engine izit anyway...?4AG??
gti_5555 i'm considering motul oil for next oil change...but my problem is i dunno whether motul 10w40 will vaporise quickly as i had use 10w50 idemitsu extreme pro previously and the oil vaporise almost 3/4 of the engine oil at 3k km...no sign of piston ring, valve seal or leaking...is diff brand got diff spec or what eventhough the gred is similar?
EGNINE:currently wat engine ru using...?how come 10w50 will vaporise so fast...?!!n yes,diff brand got diff specs...u let me knw wat engine u using den mayb ill work out sumthing for u...?
i'm using 4g93p....last time checked my spark plug...so white..maybe AFR so lean and damage the piston ring..its my mech opinion..so whats ur opinion?..already changed to motul 15w/50 semi syn..and retune my AFR..still the oil vapourise but not so quicly as before
oh~~alrite...so ure using 4100 power now...?
yup i using 4100 15w/50
