Engine Oil
hillies
Can 4G13 engine run fully/semi synthetic oil?? for eg 10-50 or 5-50? advisable? Engine's age is only about 1 year + to 2 years...
Since the thread is up....
What's is the impact of using 1 grade up from manufacturer recommended oil?
For example, my car Kancil 850cc is using 10W40 semi synth rather than 10W30 as recommended by Perodua...
thanks sifu :adore:
well,the higher rating of the 2nd number would mean that it would still maintain its viscosity during higher temp,eg like ur 40,compared to 30.
sifu has spoken....
hahaha....making fun of me meh low sai.....:P
thanks sifu :adore:
is not recomended for kancil to use thicker viscosity other then 30.40 is to thick
for the small engine.it might rub the power of ur engine.thicker oil make ur car
feel heavy.
I thought the same...it was recommended by my pomen since the enjin oledi eat oil especially during hi rpm...you know la auto 3 speed...wanna maintain 110kmh during long drive to penang....sure reach 4.5k above maa... :banghead:
he believed that the engine need top overhaul bcos the valve seal rosak already....FYI...my engine now clocking 167,xxxkm since I bought it in 2003...been :driver: alot :bawling:
feel heavy.
so meaning it just affect performance only rite...no reliability issue rite?
hahaha...wat low sai la...me still a boy ma...
feel heavy.
well, who's the 'sifu' who told need to using 40 or else..??
if u wan no power, fuel consumption turning worse....keep carry on...Malaysian...:driver:
my 'horse' oredy clock 260K, 1.6L...still using 30.....or some time 20....
never overhaulin b4...so, see no any prob....
still keep 4500rpm from KL to Ipoh...non stop....:burnout:
valve seal rosak no need top overhaul lerr.
just buka the head then change valve seal no need take out piston.
i heard from my mechanic that 4g13 and 4g15 always have valve seal rosak even though the car mileage is low.
If power is concerned...I've noticed onli litttle drop....as for FC....still about the same...
maybe after I do top overhaul, i'll revert back to 10W30 but izzit possible to do that?
Wow...what car is that.... and ur car nvr 'makan minyak itam' aaa???
Really....in that case...wanna ask the pomen how much to change valve seal onli...errr...one question though...the valve need to regrind?
yup, u may....
sifu GT_Auto, right..>??:proud:
Phew!!! better revert back...10W30 lots cheaper... :love:
but need to do oil flush rite?
lol since got this thread...
isit suitable to use 10w40 for my 4g93p bot?
sum said its better to use full synthetic
valve canot regrind lorr. later rosak or leak. all i know is that the mechanic just say he will replace the valve seal. its something like a rubber thing that block the oil to enter into the valve hole then to the combustion chamber. he say it is very common to see valve seal leak for 4g13/15. he said he ever saw a wira with 40k mileage has a valve seal leak problem.
just a broken Honda..:driver:
yup, my car dun even 'eat' engine oil or need to top up...even i harshed it kao kao...hahahahaa...
i'm using 5W30, its more expensive than 10W40...
