BMW drop in 1JZ
JERRY_VR4
1,344
14
JOHOR BAHRU
Hi zth member :
I've new project to haf a new car ...
A BMW E36 to drop in 1jz supra engine, but as i know 1jz got so many type from diff half cut , may i ask which kind is the best???
I found 1 1jz engine vvti single turbo , may i know is it the house power stronger than twin turbo? Which engine is more potential to highly modification? is it now still can approved by JPJ?
mag9556
2,770
43
1,648
Supra better(the old type)... Twin Turbo inside...hehe..
Coz drive Pajero with 1JZ 2.5litre twin turbo from supra... can do drift in auto transmittion...very powerful engine...
Good Luck..
Wira v6 MIVEC
102
Engine Bay
Get the wan from the supra or soarer..i think both of those also twin turbo..producing 280hp.:biggrin:
Wira v6 MIVEC
102
Engine Bay
Yupp using a single turbo..hp is 280..but the torque is 378NM @ 2400rpm..compared to the normal wan at 362NM at 4800 rpm..not sure bout this..try google it up..cheers!
ZoolX
24
yeah, i'm also ask same question...is it can be approved by jpj ? anyone? I'm also thinkin to put rb or 1jz....
5115
Nobody
6,104
2,254
as i know,u need to apply 1st rather than transplant.
jovi69
274
17
JPJ pass tapi yum cha a little bit le.. drop the old 1jz twin turbo le.. damn cun... seriously seremban now have more than 7 BM with 1JZ around and they are from 1 team..... imagine how fast there are...
drag_addict
480
6
sure can approve ahh dude?..heard from BMW to Nissan is definitely no go..
mine i chucked in RB25DET,until now haven't reg..:embarassed:
5115
Nobody
6,104
2,254
wow...salute la bro!
how come u never apply 1st then decide wanna convert or not?cant wait huh?
mag9556
2,770
43
1,648
Can be approved but have to follow all the JPJ rules...
I have a fren pass from JPJ by using RB20 into his old 728 BMW...
Good Luck...:smokin:
5115
Nobody
6,104
2,254
wah...BMW's V8?wonder how much it cost?how many cc?3500?4000?
MitonCT26
1,112
9
Seremban
go for 4.0 liter la...
there are 3 different 1JZ configurations. here i have to tell you that both supra and soarer have different parts and not interchangable within each other.
example: radiator. as you know the 1JZ uses viscous drive rather than fan belt to drive the fans...that's why it's so quiet even with aircon switched on. both soarer and supra have different mountings and the water outlet/inlet.
ECU also different. Supra have no TRC while soarer got.
Engine : same one la but i never understand why toyota come out 2 different layout.
Parts: Supra more common than soarer. go for twin turbo la..easier to install and more response. no lag.
there...my past experience la...maybe now different already.
E36 wanna fit 1JZ...a tight one bro... but it should be awesome once you put it in. quiet, and powerful...especially auto. hehe. have fun
kanazai2001
1,031
home
1JZ-GTE: VVT-i vs standard
The 1JZ-GTE engine has been modified by the addition of an Intelligent Variable Valve Timing System (continuous wide range intake camshaft phasing control system) and a new high-efficiency turbocharger. The engine generates 50% more engine torque at low engine speeds, and turbo lag has been reduced by 50%, while allowing a 10% improvement of fuel economy.
summary:
1.) Low to medium speed torque has been improved while ensuring high power output.
2.) Turbo response has been improved.
3.) Fuel economy has been improved.
Maximum Torque (Nm @ RPM):
VVT-i = 378@2400
standard = 363@4800
:smokin:
y2kzone7
60
Brother, i looking for 1JZ-GTE(Auto), Soarer Halfcut.
Drop me any contact ... Thank you.
JERRY_VR4
1,344
14
JOHOR BAHRU
but the runner said must only can drop in same model engine, BMW-BMW , nissan-nissan ..
i thinks still needed under table 1 ...:cheers:
mag9556
2,770
43
1,648
But my fren do all the nessary things like taking approval from HQ at Putrajaya and do all nessary things without a penny cents of Kopi-o oh...
Puspakom side, need to kowtim a bit la.. just 50 bucks onli...:smokin:
Dont know much but the windscreen got these stains of vertical rainbow lines.... tried to clean it using many methods and stuffs, still cannot.. what was the cause and how to remove it?
