wah all turbocharged...... i guess its time to do my vtec d
EG6SirT,
tis car is from kl.
Last time I heard from my fren, D16 (non vtec) with JE piston, eagle conrod, racing crank bearing, TD05 turbo, block guard, port n polish head, close ratio g/box, ori ecu + 2 extra injector manage by haltech (tat's wat he said 2 me lah) n many more performance part. Dyno at N-one by his formen n making over 260whp (i forgot at how many bar liao) Dunno is 0.7bar or 1.2bar liao. His nickname is D16 Power in tis zth forum hehe.......
my friend did a project wit his integra DA7 4dr.......B20B blk wit B16A head Crower con rods, JE 86.5 mm forged pistons.....type R cams .......Garrett T3 turbine .. US imported ecu for vtec turbo wit Greddy emanage... RM almost 40k spent but this is the best part.................... dyno at AMOIL 308whp (17' inchrims) @ 0.7 bar boost .......the car is absolutely mental
we ll keep u updated when is the next TT... u got PMed!!
wei ... remember me also ... me also want to see all your monster ride .... planning to change to Apexi W/G .. est RM1K, turbine, cast iron header & retune to hehe 1.6bar ..... 1.3 also bad traction AD wanna go 4 1.6 ... layan boost ... wuahahahahaha .... any comment ar & how's ride coming along ....![]()
"ori ecu + 2 extra injector manage by haltech" ? I tot haltech oredy on standalone EMS meh?? for a sohc to have 260whp is really the bomb!! just wondering how much boost is he runnin when dynoed...u got a monster SOHC fren there mate...cant wait to meet and learn the spec...he he. we all can learn from each other..!!
bros,
get new GM 3 bar map sensor ... cost bout RM600 .... let me know if you all interested then can order bulk get more discount .....
is it can do comunication with original ecu???
if can let me know,i wan it,
thks......
BRO,
I check with my mech & he suggest you get a SAFC to solve your problem ...
jus askin... y dont use a boost cut rather than chngn 2 a 3bar map sensor??
another thing, im plannin 2 chnge my turbine cuz nw the actuator causing probs... boosting 0.9bar... wat ball-bearing turbine basically has da same size wit a single-fin TD05???
eg6sir-t,
running well but a few leak here n there... actuator problem so boosting 0.9bar but zaki said its still safe... changing my IC n modify my valve cover 4 now...
planning 2 get my turbine chnged n mayb a wastegate... is a garrett t3 too big 4 my engine???
t3 depends on the size of the exhaust AR..if not to big its still ok..if to big then the power will go to waste as ur engine cant rev that high, when the power just about to peak, then ur engine rev just will dissappont you..
i think there a lot of sizes of t3 turbine you can opt for now...go ask Andy lar..his father got lots and lotsa turbine mahhh...he he
its always good to have external w/gate, been running 1 and half year without any prob...whois tuning ur car now??MR ZAKI LOVA LOVA?? he he he
