KELISA - Tuning
karate chop...
ur heart no pain pain ah?
U know one Learned person call Lao Tze,he say if u want to shape a tree makesure the tree not grown up yet, when the tree grow all up and u try to make it straight,that will be too late already,becos the shape already formed.
When the tree is small u leave it as bend,once grow up the tree will have the bended shape.
oo...a phrase from Lao Tze....nice
where u learn from?
BV
learn from Lao Tze ma and as a dad.
Btw here's something i dig from website:
Heel-and-toe is a driving technique used in performance driving[1]. It involves operating the throttle and brake pedals simultaneously with the right foot, while facilitating normal activation of the clutch with the left foot. It is used when braking and downshifting simultaneously (like when going around a turn), and allows the driver to "blip" the throttle to raise the engine speed and smoothly engage the lower gear.
Procedure
When a driver performs a heel-and-toe downshift, he will first use the ball of his right foot to depress the brake pedal and slow the car down sufficiently. When the car is in appropriate speed, he fully depresses the clutch pedal, cutting the power from the engine to the gearbox. Should a double clutch be performed, the driver instead shifts to neutral.
After that, the driver uses the heel of his right foot to momentally operate the throttle, increasing the engine rpm to match the required rpm for the selected gear. After that, the clutch pedal is released (or directly shifted into the correct gear from neutral during a double clutch shifting), and the engine is again connected to the gearbox.
Finally, the driver places the right foot back onto the accelerator, releasing the brakes.
[edit]
Usage
Heel-and-toe is used before entry into a turn while a vehicle is under braking, preparing the transmission to be in the optimal gear to accelerate out of the turn. One benefit of downshifting before entering a turn is a jolt to the drivetrain, or any other unwanted dynamics, will not upset the vehicle as badly when going in a straight line; the same jolt while turning may upset the vehicle enough to cause loss of control if it occurs after the turn is begun. Another benefit is "heel-and-toeing" allows you to downshift at the last moment before entering the turn, after you have started braking and the car has slowed, so the engine speed when the lower gear is engaged will not be too high.
Performance vehicles are usually modified (if necessary) so that the heights of the brake and accelerator pedals are closely matched to permit easy use of heel-and-toe, and that the pedals are not too far apart.
The name, stemming from earlier automotive designs where the accelerator pedal was on the left and could be actuated with the heel while the brake pedal was actuated with the toe, is misleading regarding how the technique is carried out in modern cars, i.e., operating the brake with the left edge of the foot, while rocking it down and to the right to operate the throttle. With practice, it becomes possible to smoothly and independently operate both pedals with one foot. The technique is common in all forms of motorsport, especially rallying.
[edit]
Note
An unrelated technique, called left-foot braking should not be confused with heel-and-toe.
Left-foot braking
eft-foot braking is the technique of using the left foot to operate the brake pedal in an automobile, leaving the right foot dedicated to the throttle pedal. It contrasts with the normal practice of the left foot operating the clutch pedal, and the right foot operating the brake and accelerator pedals.
At its most basic purpose, left-foot braking can be used to decrease the time spent between the right foot moving between the brake and throttle pedals. It can also be used to control load transfer.
However, the technique is strongly discouraged in driving on public roads as it gives no benefits and can be dangerous depending on the situation.
Racing and rallying
Karts, many open wheelers, and some modern road cars (such as the Enzo Ferrari), have no foot-operated clutch, and so allow the driver to use their left foot to brake.
One common race situation that requires left-foot braking is when a racer is cornering under power. If the driver doesn't want to lift off the throttle, and potentially cause a trailing-throttle oversteer situation, left-foot braking can induce a mild oversteer situation, and help the car "tuck," or turn-in better. Mild left-foot braking can also help cure an understeer situation.
In rallying left-foot braking is very beneficial [1] especially to front-wheel drive vehicles [2]. It is closely related to the handbrake turn, but involves locking the rear wheels using the foot brake, which is set up to apply a significant pressure bias to the rear brakes. The vehicle is balanced using engine power by use of the accelerator pedal, operated by the right foot. The left foot is thus brought into play to operate the brake. It is not as necessary to use this technique with Rear-wheel drive and All_wheel_drive rally vehicles because they can be easily turned rapidly by using excess power to the wheels and the use of opposite lock steering, however the technique is still beneficial when the driver needs to decelerate and slide at the same time.
Swedish rally legend Stig Blomqvist is considered to be the inventor of left-foot braking, developing it while driving for the SAAB works team in the 60's and 70's.
When left foot braking is used to apply the brake and the throttle at the same time it is very hard on the car, causing extra wear on the transmission and brakes in particular[3].
This technique should not be confused with Heel-and-Toe, another driving technique.
[edit]
Road use
This practice is not recommended while driving on public roads. [4][5][6]
Instead, drivers are advised to use the right foot for both acceleration and braking. The primary reason for this is that there is never any situation in a car with an automatic transmission where it is safe or necessary to apply both brake and throttle at the same time. Using one foot for both ensures that the driver can only operate one pedal.
Additionally, in emergency braking situations, it is common for the driver to extend both legs in a panic reaction. If the right foot is on the throttle, this will cause unwanted and potentially dangerous acceleration.
Most manufacturers of cars with automatic transmissions provide the car with a rest for the driver's left foot so the right foot may be used exclusively for throttle and braking.
Also, when the left foot is often used for depressing the clutch pedal this generally requires more force than operating the brake. A driver accustomed to applying this amount of force may unexpectedly slow down to an unsafe speed when attempting to use the left-foot braking technique.
Using the left foot for braking can also cause confusion when switching to or from a vehicle with a manual transmission because of the differing roles of the left foot. [7]
In addition, many modern vehicles use a "Drive By Wire" or Electronic throttle control system instead of the traditional mechanical throttle linkage. These systems have a safety interlock that prevents left foot braking. The car's ECU can detect when both pedals are pressed simultaneously and will immediately cut the engine power for safety reasons. An example is all modern Volkswagen and Audi Group vehicles.
i rather he make tons of money and buy bangalow, sport & luxury car,chun wife and tons of money for me to holidays,then again i might be dreaming too early today :biggrin:
cannot depend on himla, have secure my own saving for old age maybe i scare next i have jaga his wife food also :biggrin:
The MacPherson strut is a type of car suspension system widely used in modern vehicles, named after Earl S. MacPherson who developed the design. The first car to feature MacPherson struts was the 1949 Ford Vedette,[1] and it was also adopted in the 1951 Ford Consul and later Zephyr. It can be used for both front and rear suspensions, but is usually found at the front, where it provides a steering pivot (kingpin) as well as a suspension mounting for the wheel. Rear struts of a similar design are properly called Chapman struts.
It consists of a wishbone (A-arm) or a substantial compression link stabilized by a secondary link which provides a bottom mounting point for the hub or axle of the wheel. This lower arm system provides both lateral and longitudinal location of the wheel. The upper part of the hub is rigidly fixed to the inner part of the strut proper, the outer part of which extends upwards directly to a mounting in the body shell of the vehicle. This type of suspension is only used with monocoque (unitary) body construction since the upper mounting can be a reinforced portion of the inner wheel well. The strut will usually carry both the coil spring on which the body is suspended and the shock absorber, which is usually in the form of a cartridge mounted within the strut. The strut also usually has a steering arm built into the lower inner portion. The whole assembly is very simple and can be preassembled into a unit; also by eliminating the upper control arm, it allows for more width in the engine bay, which is useful for smaller cars, particularly with transverse oriented engines such as most front wheel drive vehicles have. For those reasons, it has become almost ubiquitous with low cost manufacturers.
Although it is a popular choice due to its simplicity and low manufacturing cost, the design has a few slight disdavantages, with regards to the quality of ride it provides and how it affects the handling of the car. Geometric analysis shows that it cannot allow vertical movement of the wheel without some degree of either camber angle change, sideways movement, or both. It is not generally considered to give as good handling as double wishbone suspensions, because it allows the engineers less freedom to choose camber change and roll center. The wheel tends to lean with the body, leading to understeer. Another drawback is that it tends to transmit noise and vibration from the road directly into the body shell, giving higher noise levels and a "harsh" feeling to the ride compared with systems such as double wishbones, requiring manufacturers to add extra noise reduction or cancellation and isolation mechanisms. Also, because of its greater size and robustness and greater degree of attachment to the vehicle structure, when the internal seals of the shock absorber portion wear out replacement is relatively expensive compared to replacing a simple shock absorber. However, despite the stated drawbacks the strut setup is still used on high performance cars such as the Ford Mustang, Porsche 911, all BMWs except the 2007 X5 [2] and several Mercedes-Benz models.
In automobiles, a double wishbone (or "upper and lower A-arm") suspension is an independent suspension design using two parallel wishbone-shaped arms to locate the wheel. Each wishbone or arm has two mounting positions to the chassis and one joint at the knuckle. The shock absorber and coil spring mount to the wishbones to control vertical movement. Double wishbone designs allow the engineer to carefully control the motion of the wheel throughout suspension travel, controlling such parameters as camber angle, caster angle, toe pattern, roll center height, scrub radius, scuff and more.
Double Wishbone Suspension
The double wishbone suspension is also often referred to as double 'A' arm or short long arm (SLA) suspension. It is commonly used in sports cars, luxury cars and light trucks.
A single wishbones or A-arms are used in various other suspension types, such as MacPherson strut and Chapman strut.
The suspension consists of a pair of upper and lower lateral arms, roughly horizontal and of similar length. The upper arm is usually slightly shorter to induce more negative camber on the outside wheel as the vehicle body rolls in a turn. Between the arms there is a knuckle with a spindle or hub which carries the wheel bearing and wheel. Knuckles with an integral spindle usually do not allow the wheel to be driven. A bolt on hub design is commonly used if the wheel is to be driven.
In order to resist fore-aft loads such as acceleration and braking, the arms need two bushings or ball joints at the body.
At the knuckle end, single ball joints can be used, in which case the steering loads have to be taken via a steering arm, and the wishbones look A- or L-shaped. An L-shaped arm is generally preferred on passenger vehicles because it allows a better compromise of handling and comfort to be tuned in. The bushing in line with the wheel can be kept relatively stiff to effectively handle cornering loads while the offline joint can be softer to allow the wheel to recess under fore aft impact loads. For a rear suspension, a pair of joints can be used at both ends of the arm, making them more H-shaped in plain view.
In front view, the suspension is a 4-bar link, and it is easy to work out the camber gain (see camber angle) and other parameters for a given set of bush locations.
The various bushes do not have to be on horizontal axes, parallel to the vehicle centre line. If they are set at an angle, then antidive and antisquat can be dialled in.
The advantage of a double wishbone suspension is that it is fairly easy to work out the effect of moving each joint, so you can tune the kinematics of the suspension easily and optimize wheel motion. It is also easy to work out the loads that different parts will be subjected to which allows more optimized lightweight parts to be designed.
The disadvantage is that it is slightly more complex than other systems like a MacPherson strut.
SLAs are very common on front suspensions for larger cars, pickups, and SUVs; double wishbones are very common at both ends of racing cars.
Prior to the dominance of front wheel drive in the 1980s, many everyday cars used double wishbone front suspension systems, or a variation on it. Since that time, the MacPherson strut has become almost ubiquitous, as it is simpler and cheaper to manufacture. Double wishbones are usually considered to have superior dynamic characteristics, load handling capability and are still found on higher performance vehicles.
Torsion beam suspension, also known as a torsion bar or torsion spring suspension, is a vehicle suspension system. One end of a long metal bar is attached firmly to the vehicle chassis; the opposite end terminates in a lever, mounted perpendicular to the bar, that is attached to the axle of the suspension arm or wishbone. Vertical motion of the wheel causes the bar to rotate along its axis and is resisted by the bar's torsion resistance. The effective spring rate of the bar is determined by its length, diameter, and material.
Torsion Bar Suspensions are currently used on trucks and SUV's from Ford, GM and Dodge. Manufacturers change the torsion bar or key to adjust the ride height, usually to compensate for heavier or lighter engine packages. While the ride height may be adjusted by turning the adjuster bolts on the stock torsion key, rotating the stock keys too far can bend the adjusting bolt and (more importantly), place the shock piston outside the standard travel. Over-rotating the torsion bars can also cause the suspension to hit the bump stop prematurely, causing a harsh ride. Aftermarket forged torsion key kits use re-clocked adjuster keys to prevent over-rotation, as well as shock brackets that keep the piston travel in the stock position.
The main advantages of torsion beam suspension are durability, easy adjustability of ride height, and small profile along the width of the vehicle. It provides a longer travel than leaf spring systems, and takes up less of the vehicle's interior volume compared to coil springs. A major disadvantage is that torsion bars, unlike coil springs, usually cannot provide a progressive spring rate, forcing designers to compromise between ride quality and handling ability - progressive torsion bars are available, but at the expense of durability since they have a tendency to crack where the diameter of the bar changes. In most torsion bar systems, especially Chrysler's, ride height (and therefore many handling features) may be adjusted by bolts which connect the torsion bars to the steering knuckles and require nothing more than crawling under the car with a wrench in hand. In most cars which use this type of suspension, swapping torsion bars for those with a different spring rate is usually an extremely easy task.
Some vehicles use torsion bars to provide automatic leveling, using a motor to tighten the bars to provide greater resistance to load and, in some cases (depending on the speed with which the motors can act), to respond to changes in road conditions. Height adjustable suspension has been used to implement a wheel-change mode where the vehicle is raised on three axles and the remaining wheel is lifted off the ground without the aid of a jack.
Before World War II, the front wheel drive Citroen Traction Avant(1934), had independent front torsion bar suspension, and a trailing dead axle, also sprung by torsion bars. The Czechoslovakian Tatra cars designed by Professor Hans Ledwinka in the mid 1930s, used all round independent torsion bar suspension, along with air cooled rear engines. Also, in the 1930s, prototypes of the first Volkswagen Beetle incorporated torsion bars - especially its transverse mounting style. Ledwinka's concept had been copied by Ferdinand Porsche, whose successors later had to acknowledge the influence of Ledwinka's Tatra models on the Porsche-designed Kdf-Wagen of 1938 (later known as the VW Beetle), a post-war lawsuit resulting in a DM3,000,000 settlement paid by Volkswagen to Ringhoffer-Tatra in 1961.
The system was applied to many new armoured fighting vehicle designs during the Second World War. It was used extensively in European cars Renault, Citroen and Volkswagen, as well as by Packard in the 1950s. The Packard used torsion bars at both front and rear, and interconnected the front and rear systems to improve ride quality. The most famous American passenger-car application was the Chrysler system used beginning with the 1957 model year, although Chrysler's "Torsion-Aire" suspension was only for the front; the same basic system (longitudinal mounting) was maintained until the 1981 introduction of the K-car. A reengineered torsion beam suspension, introduced with the 1976 Dodge Aspen, introduced transverse-mounted torsion beams (possibly based on the Volkswagen Type 3 passenger car) until production ended in 1989 (with Chrysler's M platform). Light-duty Dodge trucks however continue to use torsion bars on their front suspension.
General Motors has used torsion bars since 1966, starting with the E-platform vehicles (Oldsmobile Toronado, Cadillac Eldorado), 4 wheel drive S-10 pickups, and since 1988, full size trucks (GMT400, GMT800, and GMT900 series).
Some front-wheel drive automobiles use a type of torsion bar suspension, usually called a Twist-beam rear suspension, in which the rear wheels are carried on trailing arms connected by a laterally mounted torsion beam. The torsion beam functions both as wheel-locating arm and as an anti-roll bar to resist lateral motion of the wheels as the body leans in turns. Its advantages are that it is inexpensive to manufacture and install, and engages a minimum amount of interior volume, leaving more space for the carriage of passengers, cargo, and other components. Because the torsion bar acts in the lateral plane, not vertically, the twist-beam axle cannot provide ride-height adjustment, and it suffers, to some extent, similar car handling limitations as other beam axle suspensions. However these limitations may not be apparent on the road, because of the trend towards firmer, more sporty suspension setups with more limited wheel travel. Twist-beam rear suspensions were pioneered on the Volkswagen Golf[citation needed] in the early 1970s, and remain common on compact cars and minivans.
An SLA is also known as an unequal length double wishbone suspension. The upper arm is typically an A-arm, and is shorter than the lower link, which is an A-arm or an L-arm, or sometimes a pair of tension/compression arms. In the latter case the suspension can be called a multi-link, or Dual ball joint suspension.
The four bar link mechanism formed by the unequal arm lengths causes a change in the camber of the vehicle as it rolls, which helps to keep the contact patch square on the ground, increasing the ultimate cornering capacity of the vehicle. It also reduces the wear of the outer edge of the tire.
SLAs can be classified as short spindle, in which the upper ball joint on the spindle is inside the wheel, or long spindle, in which the spindle tucks around the tire and the upper ball joint sits above the tire.
[edit]
Disadvantages
Short spindle SLAs tend to require stiffer bushings at the body, as the braking and cornering forces are higher. Also they tend to have less good kingpin geometry, due to the difficulty of packaging the upper ball joint and the brakes inside the wheel.
Long spindle SLAs tend to have better kingpin geometry, but the proximity of the spindle to the tire restricts fitting oversized tires, or snowchains. The location of the upper balljoint may have styling implications in the design of the sheetmetal above it.
SLAs require some care when setting up their Bump Steer characteristic, as it is easy to end up with excessive, or curved, bump steer curves.
Yes Kai Meng, they are, u can source from wikipedia.org, just key-in main word like search engine,they will provide u all kind of information and link. Very useful site for just anything.
KaiMeng!!!!!!!!!!!!!!
http://www.zerotohundred.com/newforums/exterior-and-body/148271-hella-comet-sport-lights.html
here's ur Hella....hahahah
price for a pair.....
