DIY to seal tyre puncture
Have been a long time already, wanted to try DIY sealing a tyre puncture with off the rack tyre repair kit, so recently went hunting for one. There are many at the supermarket, hypermarket going at RM11 to 15 for the kit with 3 to 5 seals.
What put me off was what if I finish the seals do I need to buy another kit as I could not find any seals only on sale. Then last week went to ACE hardware and found them selling the seals. 5pcs for RM8 if not mistaken.
So since is only a trial DIY, I went for the cheapest and that was from Mr. DIY. Kit with 3 seals only but priced at RM6 only.
Tear off plastic for clearer picture
After purchase, had to find punctured tyre or any donor...hahhahaha
Then last week mechanic came over to take my car for repairs. He mentioned his rear tyre kena puncture, so found my donor.....lol :biggrin:
After an hour already like this
Remove tyre to find leak, but found leaking hole only. Something pierce through and dropped off, no wonder the leak was so fast because left a hole only. If a nail have gone through and stuck there the leak will be much slower
First use the file tool. Insert into hole and push in and pull out to clean the hole as well as to make it slightly larger so that can insert the seal
Next insert the seal through the gap of the other tool
This one came with extra glue solvent so just apply some. I think no need as the seal itself have very sticky and gooey stuff attached to it
Now time to insert the seal. This part a bit tough, need to apply more pressure to insert the sticky seal through the small hole. The main thing is to pump up the deflated tyres so it becomes more solid then easier to insert the seal in. In this picture the tyre do not have enough air pressure, as you can see the tyre surface bending inwards as I apply more pressure, therefore this makes it difficult to insert the seal
In this picture I have pumped in more air therefore the tyre surface is more solid and easier to insert the seal in
Insert about 2/3 of the seal in, then after that rapidly pull the tool straight out leaving only the seal intact
Cut off excess seal with a sharp blade and you are done
Remember to check the air pressure after this.
Thanks for viewing.....:driver:
ixeo
4,788
3,080
KL, Malaysia
Cool. Ain't nobody got time for that.
RM7 to pay my local shop to do it. So its double? triple? Since you get 3 patches for RM7
ken yeang
6,617
1,327
Nice DIY Bro Vr2turbo. Although there are spare tyre in cars, and plenty of tyre shops to fix puncture tyres.....I would still think the product is useful.......for just-in-case moments: like spare tyre deflated due to leak, no footpump, all tyre shop close.....and I am stuck in the middle of nowhere and have to be somewhere...
How is the repair patch holding up?
In the picture. Is it uncle VR hand or donor hand??? Hahaha
DIY loh, so is my hand......lol:rofl:
---------- Post added at 01:18 PM ---------- 6 hour anti-bump limit - Previous post was at 01:17 PM ----------
For the DIY kaki loh.....hhahahhaha:rofl:
---------- Post added at 01:18 PM ---------- 6 hour anti-bump limit - Previous post was at 01:18 PM ----------
your seal looks humongous @x@
After cut off okay mah!.....
---------- Post added at 01:19 PM ---------- 6 hour anti-bump limit - Previous post was at 01:18 PM ----------
So far okay....:driver:
ken yeang
6,617
1,327
Bro VR2Turbo bro now can be puncture tyre mender besides than tyre sifu at ZTH....
hazziq
46
1,508
had the same thing in my car,
cause i didnt have a spare tyre that can fit my car,
its good to have that in ur car when u didnt have any spare tyre
spare electric pump or foot pump ? hehehe....
Did my second repair last week. Friend got puncture called me ask which shop open at 9pm Saturday. Told him Uncle VR open. He came over and got it fixed. Good thing his new Innova comes with electric pump from Toyota, so no need go to Petrol station.....lol
Macam mana foot pump, just buy electric pump la, so cheap what! I have one each for my cars.
Foot pump I use before, car use but pump long time.....hhahahhaha
Those cheap pump have you tried? 3 of my friends use before says they heat up pretty hot. Say want to buy , get the more expensive and bigger units....:hmmmm:
leinnz
333
57
3,028
care to share brand/model of pump
kayour
326
41
tried it once, but fail
the tool also bengkok...hahaha
then sent it to tyre shop la
what is the engine model used in Avanza. isit same like kembara ?
did VIOS engine can fit into AVANZA ?
