sifu has spoken.
Thanks for all the input Izso!
Not sure if I'm getting all the bars at once, but, like I asked, do I really need the whole bunch?
I was talking to a friend regarding BOT and brakes yesterday too. And it dawned on me that GSR brakes would probably be more expensive to maintain because of rarity, not forgetting that the turbo itself would cost quite a bit.
5) if you are on semens, then good luck...as not much u can do with that ecu.
Aiyo bro, I said somewhere in one of my earliest posts that the 2 real bars you need is the front and rear ARBs. They make the most difference. Everything else is only if you have the budget. And I also explained the GSR brakes uses Wira 1.6/1.8 brake pads. It maybe old but spareparts is abundant. Half cut will have GSR calipers everywhere. Price ranges between 350 to 900 depending on whether the set comes with rear discs or not. So no, GSR brakes are not expensive to maintain. And did I mention it's plug and play? Yes I did.
Sikong has spoken!
But I disagree with this siemens comment. It's not that useless, just that compared to MMC it's not as flexible only.
wish I could have lots of cash
If you intend to do up the enginw, dont touch the exhaust first. Thats about the last thing you do. Im starting from handling first personally. Not sure which suspension brand to go with. :smoking:Omg...this thread is so nicewish I could have lots of cash
I'm using 4g15 vdo manual SE, so far just mod spark plug cable and drop in only, others are all stock including the rims
Planning to visit kweng to remove cat-con. Should I replace my extractor also to kweng stainless steel or stick with the SE extractor?
Hows the power output on yours?Nice. 4g15 is cheaper to maintain and mod. Still serving me since 2000 no problem except for small squeking sound here and there. The car has been cloak over 200k km before been rebuild, now at 45k +++.
134? Thats higher than I thought. Was acceleration ok? Mine seems very... Dull. Not that i did anything to the internals.Mines three speed dinosour auto. The output rather modest about 100bhp with torque about 134Nm at what rpm I forgot since its done quite long time ago.
ya lor. Factory Wira SE is about 94hp.. this only 100bhp, and not on wheel, summore with three speedo at least 20% power sudah hilang.. so modest lor
who sifu...noobie only.. hows your wira..?
The is the purple unicorn of the Japanese car collector world if you will…
There were 19 Nismo Z-Tunes produced in Japan and...
