amirfashar
Hi everyone. I am considering on buying a 2014 Satria Neo r3 and been around checking about any engine transplant but so far can't find any good info. Im thinking of transplanting evo 5 (from half cut) into the SNR3 shell and make it work on 2wd, mainly because i don't want to cut the car's rear part. evo 5 engine will not be mod as it will be my daily car(I've a 2nd gen vios so i don't mind sending this straight to the workshop after buying it) My main concern is handling. My questions are:
1. What are the other best options for the suspension aside from R3 lowered spring? Im guessing the one from the evo will be slightly higher?
2. Is there any 2-way lsd that can be used?
3. Can i use back the original gear stick, speedometer etc?
p.s., i will not have issue with JPJ/JPD if I'm to do the swap/transplant.
give coment here ..TQ
