Advice needed - BMW E30 JDM swap
A_Lee
Jan 5, 2013
11
Hello pros and sifus,
As the topic above, I would like to swap my E30 for a 3SGE or F20C. As you can see, both engine manage to tick all the requirement needed by the E30. I had seen a lot of project has been done by those who lived in the Australia as well as the native of the USA. I'm so horny to make a project of it. But I've discovered some problem:
1. My budget is only capable from RM10k-RM15K. Planning it to be a NA as far as possible. Any comments for turbo's swap such as SR20DET is acceptable but will it be reliable?
2. As far as reliable is a concern, I would like to make this car as a daily drive. So reliability is a big issue for me. (first time project). Will it pass JPJ and Puspakom endorsement? I wouldn't mind if I have to take a back door.:listen:
3. All projects conducted are only ang moh alone. I don't see any Malaysian did this. Ang Moh very clever too, make things on their own like they just pass engineering degree. Me? I want to throw it into a shop as I've had no knowledge in my hand. PLEASE ADVICE!!
P/S: My first time as an OP, please bear with me of all these long essays, for BMW purists, i'm sorry.(my family own a e46, suffered EML, Engine failure, Transmission failure, no more bmw parts for me). THANK YOU VERY MUCH!!:banghead::banghead::banghead:
A_Lee
11
I've try to avoid turbo. Hmm, as far as I concern is that turbo is not reliable, if you want to make reliable, add turbo timer. But turbo timer would be a mess on the dashboard. I wanna keep it stock. Or 1jz is reliable? I can think about if it is reliable as daily car. Thanks
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
1JZ super strong. Do routine maintenance is enough.
1jz reliability issues?
peeche
395
165
Sin City, MY
for E30 maybe you can choose either SR20 DE/DET or RB20/25 DE/DET. for SR you will enjoy better engine respond and FC. RB is quite lazy at low RPMs and thirsty too. But the sound of 6cyl is sweeetttt.!
A_Lee
11
Thank you to all for your kind input. Err, I might stick to SR20DET as the car registered as 1.8 as stock. I've scared that 2.5 1JZ won't make me pass JPJ. Does SR20DET is as tank as 1JZ?
peeche
395
165
Sin City, MY
i have no experience with SR20 DE/DET.. but this engine is proven since late 80's until the 08'-09' SR20 powered X-Trail. There must be plenty of parts available.
MKMD428
876
190
5,043
johore
go for SR20DE or DET. why?
1. timing chain. Unlike RB and 1j. so.. less maintenance there.
2. 4 pot vs 6 pot. engine oil wise. U get what I mean.
3. wiring issue....(this is when the pre-installation is done to the engine bay) SR wins compared to RB and 1j.
for 1j be it non vvti or vvti...u really2 need and expert to do the wiring.
4. roadtax is off course cheaperlah. RM880 for 2.5cc. RM379 for 2.0cc.
5. parts? its everywhere on halfcut. Unless u opted for an S15 spec R.
6. FC? keep it stock. U'll be satisfied with the FC. 6 potters are A BIT drinker due to heavy engine.
A_Lee
11
Thanks. Really a NA engine is not recommended? Because I dislike the blow-off noise for each gear changes..
A_Lee
11
Oops sorry, I was a bit dumbfounded by all your input. It is just that SR20 is an NA, which only produces 170hp (when new), while 20DET is a turbo right? Any other NA is better than SR20?
15,390
First time hearing this from a car enthusiast! :biggrin:
Like what peeche said, stock blowoff is recirculated so you can't really hear anything. Don't use aftermarket blow offs and you won't hear anything lor.
egb18c
922
94
kuantan
For the case of a sr20det, you will hear the psshhhhh sound if you only use open pod air filter without aftermarket BOV.
done it before i had money to buy intercooler piping.hehe
MKMD428
876
190
5,043
johore
compressor surge I guess.
Wilson13B
296
30
BMW S14B23 or B25 if u wan to go NA route , these engine produce a awesome intake roar !,found on E30 M3 or M3EVO .
For turbo , SR20DET should be alright , it is reliable if u don't squeeze big boost into it .
U should stay within 4-cylinder engine as to keep the weight distribution near to 50-50 , on E30 with 4-Cylinder engine the engine should be mount just behind the front axle for good handling , thats why when BMW design the E30 M3 they use the 4-Cylinder S14 engine from thier F1 machine rather than using M88 or S38 inline-6 because they want to keep the weight distribution close to 50-50 for agile handling .
A_Lee
11
Sorry for being redundant guys, thanks for all the input. I sold it after I saw some serious rust on the floor and the firewall of the car, all it does will only gives headache. Thank you guys! :damnmate:
Yes. You can now physically own a part of Zerotohundred.com! We've launched our virgin issue just yesterday and I'm excited to share this joy with you. You'd be pleased to know it'll be available at all major newsstands and bookstores so it shouldn't be too hard to spot!
Just to bring you up to speed and to keep our loyal members in the loop, this new Zerotohundred Magazine is a 132 paged, independent, bimonthly magazine that is licensed to and published...
