My plug replacement sees a big jump in performance is simply because my old plugs were worn out pretty badly.
If you use normal plugs and get it replaced every 10K, I am pretty sure the performance will be almost the same as Iridium's performance. But one important note, turbocharged cars are forced induction car. It means that our combustion chamber has a lot higher pressure (with fuel and air) compared to NA's. What does it mean? The higher the pressure + more heat, the more difficult for the plug to ignite. Thus having iridium plugs for high pressure turbo cars, will benefit.... that's just my personal opinion.
Yes, you are right. Read it somewhere that under high pressure the spark harder to jump. Was asked to set the ground electrode nearer so gap becomes smaller. Best was change to platinum rather then normal ones....
Hi senior & knowledgable members ,
