Airtrek exhaust
Poacher
Auckland, NZ
Hi guys,
Need advise. I think original airtrek exhaustis 2.5" at max, smaller in some places. I need 3" does the evo 7 3" kit almost bolt on with small modification at the end?
Is there a 3" cu2w exhaust kit that anyone knows of for a reasonable price online?
Thanks!
Singapore still have sale Original from Apexi exhaust PNP item.
Please look the picture stock airtrek Plug and Play no need to exchange any, BTW i swop my full exhaust system with singapore car and install in JB.
i only take rear Apexi exhaust picture, full exhaust pipe picture didnt take it,
down pipe to rear 3" (track racing type) not JPJ friendly then connect to Apexi exhaust.
Poacher try autobend aka rage exhausts. I recently had a 3in turbo back kit fitted to my atr from them. Cost approx 1100. Mine was abit more as I had wideband bungs etc welded on. It sounds good. If u want a video of it just pm me.
I rung them apparently they don't do the Rage for the Airtrek anymore :( I can get a full custom for around $800 ish for the back part i just need to supply a 3" front pipe.
Oh gutted. I got mine a few months ago. I know somone who can get a apexi cat back system, was a little more expensive though
did u use 3in pipe with stock engine? any disadvantages?
Yes 3" from the dump pipe
Not exactly stock. Td05, 875cc injectors, fuel pump etc etc running 20psi. Only disadvantage is it sounds funny cause of autobox.
Poacher you could also buy a autobend evo7 kit and have that installed with some mods.
Yeah i was thinking that, apparently Russell said the front pipe needs a reasonable amount of modification :S It's almost worth just getting custom.
Yes 3" front pipe on standard is OK. (3" straight through better). and remove CAT and better TIP/end. I have DECAT 2.5" stock exhaust with RPS end/tip. It runs nice and sounds nice but is quite loud i think my RPS not very good. i am going to put s/s 3" front pipe on and then my exhaust should be good for the td05.
3" straight front pipe to Apexi exhaust + Tomei 260 Procam + Stock TD04HL + FMIC.....
sound have a bit like Boxer engine (cooking water)...
Police and JPJ Alway like to block my ride.... (-_-)
Has anyone got some airtrek evoscan log xls files they can email me? pref with a td05 setup i want to compare load etc to my setup to try sort out issues.
Write your reply...
