Airtrek exhaust
Load calc, TPS, RPM, speed, knock sum, just the basics in second from 2k-6.5k to compare, my load gets to almost 280 in some cases around 3k full boost then drops down to 210 load by 6500 rpm just all weird flow issues! and it feels like sometimes it's pulling timing but the logs say it's not..... (0 knock sum or 1 knock)
I can flick you some too if you like. You probably want to turn on 2 Byte load in your ROM too so you get exact load figures rather than the load calculated number which is not that accurate.
I'm hitting 270 load at 3900 RPM (23psi) and it drops down to 215 by 6800RPM (20psi)
