Wiring section? I don't understand.Nice try bro...can you snap a pic of the wiring view from top..so I can give some input on how to improve the wiring section that you might miss...
thats why using the breadboard easier...Wiring section? I don't understand.
I think i too rush on this, made mistakes.
I punched the hole to near to each other. I nvr do a good measurement.
nvr tot of that ma. I always cut costs hahahathats why using the breadboard easier...
can arrange then test...even can arrange as wording or symbol what...
bread board not that expensive also
You trail and error maybe more cost and time liao......nvr tot of that ma. I always cut costs hahaha
Well, all these adds up to experience.You trail and error maybe more cost and time liao......
In a way, true also. The more you do, the more experience you get. Learn through mistakes....Well, all these adds up to experience.
Btw, breadboard is plastic too right? Can it withstand the solder heat?
And plus, i just started to learn how to solder, i had a few cold solder. Bad.
Expensive experiences. HahahaIn a way, true also. The more you do, the more experience you get. Learn through mistakes....
So far, the LED's are cheap.....Later try something more expensive then cannot do too many mistakes......hahahahahaExpensive experiences. Hahaha
Lights modding are cheap actually. eBay are there to helpSo far, the LED's are cheap.....Later try something more expensive then cannot do too many mistakes......hahahahaha
you don't solder on breadboard.Well, all these adds up to experience.
PCB is different thing is ti?you don't solder on breadboard.
a soldering aid like the soldering helper with arms are cheap rm20ish only and is a good buy if you solder often.
solder iron wattage also important. I use a 60-100w for car wires that are thick, and 25-40w for components.
breadboard was designed to hold electronic parts and soldered...Well, all these adds up to experience.
Hmm, nvm. DIY better.breadboard was designed to hold electronic parts and soldered...
one face plastic...another face got copper strip for soldering...
another type of bread board is cucuk2 type...just insert the leg...and good to go (self locking port)
