Help !!! Water stain remover causes matte surface ...
Bro.,
Where do you get the mirror to replace the side mirror? Those from glass shop are one to one mirror.
Original side mirror are convex mirrors, that is why the reflection looks smaller and wide angle...
I got the side mirror from Jalan Pasar. Both the wira and putra was using normal mirrors. Non convex. I dun think all side mirrors are convex. If it is, it should have a disclaimer there stating "Warning, objects may appear closer than actual" or something like that. But hey, I could be wrong and I stand corrected if I am mistaken.
---------- Post added at 04:18 PM ---------- 6 hour anti-bump limit - Previous post was at 04:15 PM ----------
Did you use those Forma Head or Tomcat water stain remover from supermarket shelf?
If yes, still can remove but tough work. Got a few member kena on their front windscreen. Have to polish with machine to remove. Even with machine and compound took some time to do it.
Side mirror difficult to use machine. By hand will be tough work....
Which is why I suggested to TS to try using polish or compound. Remember that side mirrors are plastic whereas front windscreen are glass. So it may or may not work. But yeah, those rain stain remover thingy, keep it away from side mirrors and windscreen with wipers.
My side mirror original also glass. If plastic, then even rain X sometimes can blur them....
Oh! I check mine and is convex. Even the glass shop I went to, he already inform me once I said is side mirror, that what he can give me is normal glass only as many side mirror are convex.
If you want to replace only just the mirror, it should be less than RM40 tops. Wira ori one is RM20+ only.
If you want to replace the whole side mirror casing and all, I only have 2 words for you : Half...Cut..
My Sonata III cannot get half cut one also......:banghead:
For you it's 3 syllables : mo-di-fy.
:biggrin:
For DIY sifu, is easy to say......:top:
I got the glass replaced. Problem is the outer cover broken too. Survey all the Kg. Subang chop shop also don't have. If mod have to change both sides, if not look funny.....:biggrin:
Get putty filler la. That one easy DIY. Then spray diy using touchup paint.
Yup, that was what I intent to do, but putty cannot because one chunk came off. Intent to make a mold then use epoxy mixture. Spraying no problem as the spray painter have promise to spray if I can repair it, since he also cannot find replacement.
