Billet or Cast Compressor Wheel?
Timeattacker
Johor Bahru
Hi To all Senior,
Anyone can suggest or give an idea on choosing between Billet or Cast made Compressor Turbo Wheel??
THanks
:listen:
Hi To all Senior,
THanks
:listen:
it quite easy either to use billet wheel or not..if you can afford it..go for it...if not..cast wheel r great too...turbo selection r the most important thing..
Billet or cast are more on maximize the potential of the selection turbocharger frame......:listen:
from my reading bout dis billet wheel,the only advantage using this billet comp wheel was being durable and stronger compare to cast comp wheel if the design still using oem cast comp wheel..it said that it will not flow better,spool any faster if the billet wheel design still same with the oem one..
more advantages can be achieve only if the billet wheel hv different and better design compare to cast comp wheel..
is this true?
