ahmedshaikhani
@ahmedshaikhani
It looks from the video that it's not an RS, since RS engines don't have the resonator at the intake piping to the throttle body, or you can double check by giving me the code of your ECU.
If you plan on getting 12.5:1 compression, you will need to shorten the block or use thinner gaskets, it's quite hard to know what the static compression since not all engines produce the same amount due to wear and tear. Best to use a compression tester to be sure.
I will be using compression tester to make sure its the right compression. But stock OEM gasket of 4G92 Mivec and Mivec pistons will make 12.5:1 or 12:1 or not ? I will be using standard mivec pistons. I don't know is it Mivec RS or not. :) But I don't mind, I have to focus on what I have now.
Width size? See it yourself:
