Dear all,
Would like to ask what are the values you are using on the alignment of your car? Currently i am running slight all toe in all 4 wheels around (tuned by the tire guy), camber and castor untouched at all. However, many tire guys informed me that the rear camber readings of my GT is not negative enough, affecting cornering stability, keep suggesting me to change to adjustable rear camber kit so they can adjust it. Normally i know they will try to con people to buy the front camber bolts.
My reading as per below:
Front Left Front Right
Toe +0.5 +0.3
Camber - 0.8 - 0.5
Rear Left Rear Right
Toe +0.7 +0.7
Camber - 0.4 - 0.3
So peeps, do these values are good? These are so called "custom" figures for my alignment, the car and steering drives straight but while on the highway, the car can slightly pull to the left as the crown of Malaysian roads. Cornering still fun though.
I would like to hear your opinion :)
Toe +0.5 +0.3
Camber - 0.8 - 0.5
Toe +0.7 +0.7
Camber - 0.4 - 0.3
