Evo 8 MR VS Evo 8 - different between engine (internal parts)
BDK8671
223
6
Hi All Sifu ....
hope your all can comment what the different between Evo 8 MR engine (internal ) VS Evo 8 engine?
beside for the ball-bearing turbo, Cam shaft .
izzit Piston they using the same ? ....
Thanks for comment ....
BDK8671
223
6
I tot only the roof is aluminum .... rear bonet as well ?
EVOFans
246
61
IINM the camshaft profile is slightly different and there is minor variation in turbocharger
Other than that there are no difference
And oh yes,stock EVO Turbocharger never did come with Ball Bearing
EVO Hood/Trunk is always made from aluminum(CT9A anyway)
Aluminum roof only on CT9A after EVO VIII MR and no sunroof
jameswwt
1,127
78
1,648
Well said...:driver:
H22-C
642
74
Evo8 rear trunk is not aluminium, it is damn heavy metal. don't believe? take out yours and see.
but i m not sure about Evo8mr rear trunk.
H22-C
642
74
aycy, mine is Evo8MR. ss it is aluminium ? i never take out, i am not sure.
karl_razlie
514
56
5,028
Puchong
the different MR version wth others ver 8 they came with a revised limited-slip front differential, aluminum MR shift knob, handbrake with carbon fiber handle, 17 inch BBS wheels, aluminum roof, and a 6-speed manual gearbox. The new Evolution also sported chrome housing tail lights and head lights.MR also uses slick-response Bilstein shocks for improved handling. Detail improvements have also been made to Mitsubishi’s own electronic four-wheel drive, to the ACD 5 + Super AYC 6 traction control, and to the Sports ABS systems.
seperlinky
200
3,018
Evo 8 rear trunk is not alu, only the front bonnet. Try with magnet
EVOFans
246
61
Actually what you said above is more or less applies to USDM Model but not JDM Model
JDM Model 8 vs 8 MR=
1.)Bilstein Shock
2.)Aluminum roof on non sunroof car
3.)Different interior(Alcantara trim for VIII MR,Feux-Carbon Fiber CF Trim on A/C Srip)
4.)BBS Rim
5.)Vetex Generator
6.)Exposed Carbon Fiber Rear Spoiler
7.)Smoked Headlight and Tailight
8.)Slight different on turbo/camshaft/piston as mentioned above
H22-C
642
74
evo8mr trunk is metal, i have tried with magnet.
test result with magnet:
(1) stock front bonnet >> not stick
(2) stock front fender >> not stick
(3) rear fender (part of body shell) >> stick
(4) rear trunk >> stick
ops... forgot to test the roof.. hihi...
I owned Proton Wira 1.5m and now my car always jerking when im driving.. Can someone recommend me any good/cheap shop around KL/Batu Caves that can fixed this. I already send my car to 3 different shop but still the same.
