Hey guys, I'd appreciate any advice give on a particular problem I'm having with my car. I have a 4G92 MIVEC engine (using standard 4G92P engine block, crank and pistons), using the standard air filter, intake manifold and MIVEC extractor. Exhaust is a 1.7" pipe from the flexi-joint right to the back, with an S-flow muffler (in/out 1.7").
Recently, I've been experiencing some pretty bad acceleration with it. Thought it was in need of maintenance so I got it serviced. Currently using Pennzoil 20W-50 mineral engine oil and BKR7EKC-N-11 plugs. No difference after servicing as well :(
Even with the air-cond off, I notice that I've got to slowly press the accelerator in to get the best pick-up. Too much input and it becomes heavy (engine sounds strained but RPM climbs very slowly). Any idea what the problem could be?
I suspected a blocked exhaust system (symptoms are very similar), but there is air coming out of the tailpipe, and it's pretty warm, so I guess that's not the case....
[/U...
