i remove my thermostat in my saga
I hope you meant for the flush. If it's permanantly out, good luck to you
lol..then?
my radiator is rusty inside,not using any coolant..only tap water,how to clean the rust inside?any chemical or products that i can use?
planned to flush it and use a coolant..
nothing happen to my radiator (my proton saga), temperature still normal, and no worries if the thermostat fail to work as it is.![]()
Unless you have a water temp meter installed, you can't really use the temp gauge on your dashboard as a accurate reading. You have to remember that engine oil has an optimum temperature to reach before it starts to lubricate properly. For example, 5W30 means the engine will need to be 100 degrees before it starts lubing at 30 weight oil. Inbetween that you're not getting full lubrication except from the 5 weight oil properties. Just make sure your car is fully warmed up before you drive your car agressively. There's a reason why the thermostat was designed into the system. If it really was useless manufacturers would have just saved money by not giving it to you.
yup maybe u are right. i have to warm up my saga at least 10 minutes before i can drive it smoothly.
by the way my saga already reach 12 years old and by removing the thermostat is to avoid that thermostat fail to work and cause overheating during my journey that what i am afraid of.
can we fill up with 2 bottles of coolant?
I always use 2 bottles and top the water regardless of the ratio. Rad fan hardly kicks-in whenever the a/c is in use....LOL!That's pure. It has to be mixed 1 part to 10 with water. You can't use that only la. Not good!
not good?why?
so which coolant is the best?can u suggest?
You have to go try yourself. I've never really bothered to experiment with other brands since stock Nissan / Toyota / Proton ethylene glycol coolants all work for my cars.
Like what ReLog said try Millers. There's Motul and a few other reputable brands that's worthwhile testing too. For me it's always about cost and the ones I use are the 'cheapest' reputable ones.
I use a brand called Showa. It says mix 50:50. So 2 liters of coolant + slightly lesser than 2 liters of water makes up about the right concentration. So I got it right lah... About the hammering parts... since you are quite a sifu now, no good to hammer you in public, will guide you through when we meet.
.......Mazda said the RX-8 Hydrogen RE, based on its popular RX-8 sports car, gets around...
