wanna ask about this 4chnl amp.
here are the spec
240rms watt..frequency response=15Hz~25KHz..x-over type=LPF/FULL/HPF..LPF=30Hz~250Hz..subsonic/HPF=40Hz~1KHz..bass boost level 0db,6db,18db..minimum load=2Ohm
can this amp power my 60w rms comp set n 1 double coil woofer? im not sure the woofer W but its a orange mohawk brand -.-..can the amp support it n wnt boom anything?
here are the spec
Thanks
