Lanzar OptiDrive 1400D Mono Block
SPECS
500 Watts RMS Power @ 4 Ohms
800 Watts RMS Power @ 2 Ohms
1000 Watts RMS Power @ 1.3 Ohms
1300 Watts Max Power @ 1.3 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to +18dB
Phase Shift Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 4
Dimensions: 10.08'' (W) x 2.12'' (H) x 14.96'' (L)
COD JB Rm1300
Interested Pls Call/Sms 0167902914
SPECS
1 Ohm Stable
MOSFET Power Supply
Remote Bass Control
Soft Turn On/Off
S/N Ratio: 90dB
COD JB Rm1300
