http://img473.imageshack.us/img473/1318/dsc001741ni.jpg
Clarion DPX 1001.2
specs:2/1 channel
Maximum Power Output 1000W
Continuous Average Power Output 300W (150W x 2 into 4 Ohms 20Hz-20kHz @0.05% THD)
Typical 2-Ohm Stereo 300W x 2 @ 0.5% THD
Typical 1-Ohm Stereo 500W x 2 @ 0.8% THD
Typical Bridged Power 1kHz 1000W @ 1.0% THD
RM800
http://img473.imageshack.us/img473/658/dsc001775tg.jpg
Phoenix Gold Octane-R 2.5:2
RMS Power @ 4 Ohms: 50W x 2 @ 14.4V
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 150W x 1 @ 14.4V
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 15 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >110 dB
Fuse Rating: 20 amps
RM450
http://img473.imageshack.us/img473/7131/dsc001784so.jpg
Steg Masterstroke MSK3000
4 ohm stereo - 400W x 2 RMS
2 ohm stereo - 800W x 2 RMS
4 ohm mono - 1600W x 1 RMS
2 ohm mono - 3000W x 1 RMS
RM7000
http://img102.imageshack.us/img102/5250/dsc001827rw.jpg
SOUNDSTREAM Lil' Wonder 2
Low-/Highpass-Filter 50 - 6500 Hz
Bandpass function
Bass-Boost 0/6/12 dB
2 x 60/120 Watt RMS @ 4/2 Ohm
1 x 240 Watt RMS @ 4 Ohm bridged
rm650
http://img473.imageshack.us/img473/4862/dsc001855yc.jpg
Precision Power Inc. A204.2
25 X 4 @ 4 Ohms
50 X 4 @ 2 Ohms
100 X 2 @ 4 Ohms
RM500
DLS RA40
Number of channels : 4
Nominal power in 4 ohm : 4 x 50 Watt
Typical power in 4 ohm : 4 x 75 Watt
Typical power in 2 ohm : 4 x 110 Watt
Typical power in 4 ohm bridge mode : 2 x 220 Watt
Frequency range : 10 Hz - 50 kHz
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance, low level input : > 10 kohm
Input impedance, high level input : 330 ohm
High level input with auto start function : Yes
nput sensitivity, variable : 0.2 - 7 V
Grand bass filter : variable 0 - 18 dB
Variable phase shift control for subwoofers : variable 0 - 180 degrees
Filter, highpass, variable : 20 - 150 Hz on all channels
Filter lowpass, variable : 40-125 Hz on ch. 3/4
Filter slope : 12 dB/octave
Current draw, idle : 0.9 A
Current draw, maximum : 50 A
Dimensions W x D x H : 359 x 245 x 59 mm (14.1 x 9.65 x 2.33 inch)
Weight : 4 kg ( 8.8 lb)
http://img473.imageshack.us/img473/2327/dsc001837qo.jpg
RM1500
http://img473.imageshack.us/img473/1746/dsc001811fp.jpg
Zapco I-Force 450
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
RM1500
Soundstream Reference 644S
http://img129.imageshack.us/img129/2928/dsc001878hn.jpg
75Wx4 @ 4Ohms
150w x 2 @ 4Ohms
1ohm Bridge Capable
RM850
Xetec Vector V350.6 amp picture.
http://img129.imageshack.us/img129/3564/dsc001896ca.jpg
4x50 Watt + 2x75 Watt an 4 Ohm
4x63 Watt + 2x90 Watt an 2 Ohm
2 x 125 Watt + 180 Watt in bridged mode at 4 Ohm
2 x 125 Watt + 250 Watt (2 Ohm) in Bridged mode
RM950
Another new STUFF...
Xetec Vector 150.2 Amp
RM750
http://www.xetec.de/include/include_block/produkte/produkte_popup.php?productID=25&show=techInfo
Soundstream Picasso Reference
RM750
http://img163.imageshack.us/img163/4820/dsc001948rf.jpg
Clarion DPX 1001.2
specs:2/1 channel
RM800
Preamp Outputs: Yes
RM450
RM7000
Bandpass function
rm650
25 X 4 @ 4 Ohms
50 X 4 @ 2 Ohms
100 X 2 @ 4 Ohms
RM500
DLS RA40
RM1500
Zapco I-Force 450
S/N Ratio: >90dB
RM1500
75Wx4 @ 4Ohms
150w x 2 @ 4Ohms
1ohm Bridge Capable
RM850
RM950
RM750
RM750
