Magnat Bullpower One - Monoblock & JL Audio Sub 12W3
Magnat Bullpower 1 series- from Germany, Monoamp for sale..
Item is used for 1 year, but condition still very new...can test 1st..no scrathes.
Price going for RM 450.
JL Audio Subwoofer - 12W3 D4.. with custom ported enclosure for sale.. Genuine sub..can test before purchase... Selling at RM 450 also.
Specs: 1-channel Car Hifi amplifier
Max power output into 4 ohms Sinus Burst 2:8, 1kHz, 14,4V
Mono 450 Watt
RMS power output into 4 ohms DIN 45324, 14,4 V
Mono 225 Watt
Max.power output into 2 ohms Sinus Burst 2:8, 1kHz, 14,4V
Mono 800 Watt
RMS power output into 2 ohms DIN 45324, 14,4 V
Mono 400 Watt
Impedance Channel 1 2-8 Ohm
Frequency response 5 Hz - 100 kHz (-3dB)
THD << 0,05%
Übersprechdämpfung > dB
Signal-to-noise ratio >< 100 dB dB
Input sensitivity LOW LEVEL INPUT 0,25V - 4V
Input impedance LOW LEVEL INPUT 50 kOhm Ohm
Variable low pass channel 1 from 50 Hz
Variable low pass channel 1 to 500 Hz
Flankensteilheit Tiefpassfilter 12 dB / Oktave
Variable Bass Boost to 12
supply 12V (10-15V)
Specials 2 ohm stable Variable low pass 50 - 500 Hz (12 dB per octave) Variable bass boost 0...6 dB at 45 Hz Variable subsonicfilter 10 - 50 Hz ( 12 dB per octave) Low level pass through RCA jacks Bridge- capability Gold plated RCA connectors Gold plated screw terminals for speaker and power supply Protection circuit that safeguards against short circuits, DC-offset and overheating Green operation and red protection indication LED
Mono 450 Watt
Mono 225 Watt
Mono 800 Watt
Mono 400 Watt
THD << 0,05%
supply 12V (10-15V)
