PRICE REDUCE!!! MAGNAT bullpower 2 channel amp!!! stil got few units ONLY~~~
Im here have limited stock of Magnat BullPower 2 channel amp for sale..
It's NEW!!!!!
GERMANY TECHNOLOGY!!! NOT made in china 1.. DONT WORRY!!!
the price is RM300!!!!! (nego)
for those interested,can cal me at 012-3898926..
or u can pm me..
thanz!!!
here is the pic:
Bulldog power with new form and technology. The new generation of Magnat's Bullpower range runs stable at 2 ohms, is equipped with variable duplexor filters, adjustable bass boost and subsonic filters. Solid head sinks and high-performance power supplies create the conditions for the unleashing of enormous power.
Magnat Bull Power Two
Max. power output into 4 Ohms - 2 x 130 Watts / 1 x 400 Watts
RMS power output into 4 Ohms - 2 x 65 Watts / 1 x 200 Watts
Max. power output into 2 Ohms - 2 x 200 Watts
RMS power output into 2 Ohms - 2 x 100 Watts
Technical Description
# 2 ohm stable
# Variable low pass 50 - 500 Hz (12 dB per octave)
# Variable bass boost 0...6 dB at 45 Hz
# Variable subsonicfilter 10 - 50 Hz (12 dB per octave)
# Low level pass through RCA jacks
# Bridge- / Tri-mode capability
# Gold plated RCA connectors
# Gold plated screw terminals for speaker and power supply
# Protection circuit that safeguards against short circuits, DC-offset and overheating
# Green operation and red protection indication LED
Max. power output (Sinus Burst 2:8, 1 kHz) into 4 Ohms, 14,4 V - 2 x 130 Watts / 1 x 400 Watts
RMS power output (DIN 45 324) into 4 Ohms, 14,4 V - 2 x 65 Watts / 1 x 200 Watts
Max. power output (Sinus Burst 2:8, 1 KHz) into 2 Ohms, 14,4 V - 2 x 200 Watts
RMS power output (DIN 45 324) into 2 Ohms, 14,4 V - 2 x 100 Watts
Frequency response - 5 Hz - 100 kHz (-3 dB)
THD - 0,05 % (1 kHz)
Signal-to-noise ratio (A-weighted) - > 100 dB
Input sensitivity - 0,25 V - 4 V
Input impedance - 50 kOhms
Power Supply - 12 V negative ground
Dimensions (WxHxD) - 267 mm x 58 mm x 237 mm
Weight - 2,5 kg
It's NEW!!!!!
or u can pm me..
thanz!!!
here is the pic:
# 2 ohm stable
Weight - 2,5 kg
