Choosing the perfect Engine Oil
Shell Helix
Oct 3, 2011
11
14
503
Most off-the-shelf lubricants are acceptable products to be consumed by your car’s engine. But to extract the most from an engine while maintaining it in a good health in the long run, it is impeccable to feed it with the best lubricant money can buy.
A better oil would also mean that is is better at lubricating the engine’s moving parts, while staying in optimum operational fluidity and with the ability to clean the engine’s internals with active cleansing detergents as well as deterring corrosion,improving sealing and in removing heat from the engine.
There are also important ratings in a particular bottle of oil one should know before attempting to pour it though the engine oil filler. A crucial rating would be the Viscosity index that determines how an engine would perform depending on the rating chosen.
Viscosity
Very simply, Viscosity means how easily a liquid pours or flows. The Society of Automobile Engineers (SAE) made this a recognized International standard and depending on the region you liv e in and engine type, acceptable viscosity rating may differ from as low as Zero to as high as 60.
The lower a number in a viscosity rating, the thinner the oil is and the easier it flows. For reference, a 10W-40 rating generally means that it is a multi viscosity oil. The “10W” index refer to how the oil flow at lower temperatures like in a cold winter and ’40” refers to its flow rate at higher temperatures.
Your car’s Owner’s Manual should be able to tell you the recommended Viscosity rating you should use for your car’s engine.
More about Shell Helix Ultra Engine Oil
jameswwt
1,127
78
1,648
Where is the best place to get secured original Shell Helix engine oil???
As fake engine oils is everywhere nowadays...
ah-singh
575
bro,
I normally get my Shell Engine oils in the Shell petrol stations.. Thats the only place you can get the original stuff...i hope...
AD_EG
6,000 RPM
6,328
231
Ipoh
the thinner the oil, the easier it flows, but that also means if its too thin, it can lose its lubricating capability when too hot and cause more wear.
how low is low is where im a bit unsure... vehicles in malaysia who dont have winter, can use 0w oils right?
based on our temperature ,your oil temp should be no more than 120C or 250F, meaning example 5w-40 or 10w-40 oils should be more than sufficient to run our cars? so why do we go for fully synthetic or oils that has 15w-50 ? when we are barely reaching that temp? and only reducing the oil flow in our engine?
any sifus can advice..still quite unsure about all this.
Waiyuan Kooi
From Facebook
Nov 15, 2011
27
503
www.facebook.com
about want to get 100% original shell engine oil u can go to petrol station, they are supply by direct shell.
---------- Post added at 01:03 AM ---------- 6 hour anti-bump limit - Previous post was at 12:56 AM ----------
about AD_EG question.
i got abit want to explain about this. Alot of ppl is thinking low visco oil will cause more wear, that is wrong.
U can see alot of racing oil also is low visco like 0w20, like the famous racing oil - motul, they also got alot of low vis racing oil.
So all i want to tell is WEAR is not about visocity, wear protection is from addictive & not from visco. and i have a friend just get a new kia forte, the lowest visco is OEM book is 5w20, that is the thing.
i am not good to reply by word. So i think will be abit confusing.. lol
carent9
252
13
Selangor
Boss...what is the best viscosity for 4G93P engine...road use n sometime "weekend"...
I would recommend 10w/40 or 5w/50.. Should be good.. this is what I am using. My slightly tuned car cannot take 5w/40.. need to top up oil most of the time...
l2s_turbo
1,068
154
3,163
What will be the best engine oil grade for 4g63t?
Dear sifus,
I have got a big problem here. Today itself while I'm cruising along LDP .. the engine died itself when I'm trying to make a U-turn at damansara jaya. I got shock WTF?! why is my steering wheel so hard to turn .. then only I realize my engine already turned off. :blink: .. Behind me a red satria nearly kiss my butt but lucky he didn't, i quickly start the engine and gave a friendly wave and sped off. Then on LDP driving just pass Kelana Jaya flyover (Western Digital) engine...
