Water to Air Intercooler
cmng
3,289
72
Anyone know where to get this kind of kit ?
not easy to find it at Malaysia except oversea
DanzEterna
15,911
3,371
www.primeperdanaclub.com
just use a very long hose & just connect your windscreen washer to to
the front of the intercooler......when u press your wscreen washer, yr ic get sprayed too :rofl:
yeehau86
Feb 10, 2007
2,856
2,425
there is water spray kit for top mounted intercooler cars such as Subaru, but not sure whether it works for front mounted intercooler cars.
cmng
3,289
72
to all ZTH..
I asking about water to air intercooler kit le
not the intercooler spray kit
peterj
1,321
258
1,683
Kuching
there is one feller selling in zth market place bout 1 month ago, not sure sold or not....water to air intercooler only got 1 problem, u need a extra water pump (electrical) and radiator to circulate the heated water which is space consuming
cmng
3,289
72
peterj.
I know that
just looking another option to source the IC locally for clearance measurement
worry order thru oversea.. clearance not match then eat shit liow
Dayline668
1,810
492
1,683
Y not just air to air intercooler..? isn't that more cooling efficiency. Except u running nitrogen in the coolant...
Dayline668
1,810
492
1,683
Yes.. if the car is moving, stop n go will still heat soak the sucker like a subaru, the best part is response when driving on stock cooler, nothing better. If u look at charge vehicle nowdays, especially VW hot hatch, front mount big facing thin intercooler for response n cooling. Toyota stop designing water to air intercooler for a reason.
Suggestion on the pump, mod it to run constantly(will reduce pump life span but best when stop n go), adding a fan to the cooler also, in malaysia weather this is a must. Happy modding...
jinkl
4,624
376
3,183
i guess u make one yourself, usually they take a small intercooler such from GSR or SR20 or such , then u need to weld the enclosure which can be done locally too , then u can use a 12V water pump to circulate the water :)
cmng
3,289
72
jinkl
those water to air cooler have different core
some quote from Air to Water Intercooler
Some Water to Air Intercoolers that you can buy online do not contain true water to air cores. A true water to air core has water passages that are much smaller than the air passages. This is part of what allows the water to air intercooler to be so small and have such low pressure drop. Some water to air intercoolers that you buy online use an air to air core design where the air passages for ambient air and intake air are the same size, with an enormous loss of efficiency.
Of course the kit I looking at mostly come with pump
it just the size concern only
need to get the right size only
virqai
206
393
1,563
jinkl
usually in here when we do fabricate water intercoolers we use an aircond cooling coil..and pump we use from bot water pump...and its for drag car coz we use ice,and put in small ice box...heee:biggrin:
The Marketplace Top Posts
Hi I have a Lancer with a swap to a 4G92 MIVEC as per the picture:
Recently the oil pressure has started to go low when the engine is at idle/tickover.
This is shown on my oil pressure gauge as well as the oil light on the dashboard had been flickering.
Also the car won't go into MIVEC mode.
I have checked the oil, it is at the correct level on the dip stick and was only changed about 3000 KM ago, running 10W40 fully synthetic...
