How many of you here runs turbo with both watercooled and oil cooled? Mine was just cooled by oil and my freinds told me its a big no no. watercooled needed as well
i don't really get your question here. You are saying that your turbo lube-oil is water-cooled and you have coolant on which side of the turbo?normality78 said:blackhowling bro,
Happy new year bro. long time nvr hear frm u in the forum. pls correct me if im wrong. Issit mostly big turbo (anything after T3) doesnt really need watercooled anymore?
Kippo bro,
This lead me thought of another thing. Lets say should i have watercooled my turbo as well, does it help in more stablizing my oil temp or even might reduce my oil temp abit since coolant already helping out to cool out the turbo? Less turbo heat, less oil heat?
Khoyos bro,
The info i found out was due to larger turbo spool up times was less frequent as small turbo that more freq boosting up due to it smaller size hence larger turbo doesnt really need the watercooled. Not sure how true it is though but it does make abit sense
you are right that water is better as heat transfer agent because its thermal conductivity is higher that oil. But it is not suitable to be used in high temperature application due to its limited physical properties as explained by Lennon.140dB said:i dunno about ur oil to air or oil to water heat transfer theory, but what i know for a fact is that water is the best agent to transfer heat...
It will depend how much capacity margin that you have on your radiator. There is a possibility that the cooled water temperature will be higher. In turn, your engine may be slightly warmer since the engine cooling water jacket is getting slightly warmer cooling water. It is your turbo that will be cooler but at the expense of your engine. But you can improve it by using bigger capacity radiator but only if your current radiator does not have that extra capacity margin.normality78 said:Kippo bro,
so i was curious. If now i go and hook up the waterjack on my turbo, which will use my radiator water to cool the turbo as well rite? If so, would it possible that ow my water temp will go higher since its sharing the heat load that all the while my oil is bearing? Would it possible that my oil will less heat since water is sharing partially of the heat?
