Unable to find answer for 96 and 99 civic. Please help!!!
Hikaru
3,665
22
Atlanta, GA
photobucket.com
It's all the same from all years, Plug and play.
However, I have seen many people doing different shits when mounting 99-00 bumper on the 96 body. Some just cut the bumper horizontally around the number plate area to mount the lower portion of 99-00 on the existing 96-98 bumper. It's easier to change it back under such case, just plug and play back.
Some people actually use the 99-00 completely with 99-00 grille, but make some filling on the hood and headlights area to force the 99-00 bumper goes on it. If that's the case, you are doomed.
Venzonic
37
Sensei~Hikaru-san, doomo..
Do u means filling with fiber (cement alike thingy) at the gap between the headlight and grille + hood and grille to close up the gap?
If that is the case, anyway for me to change it back to 96 configuration?
For ur info, my current configuration have a big gap between the headlight and grille...
thanks...
Venzonic
37
Oops...it is not a big gap btw headlight & grille but is the big gap btw headlight sharp edge (which pointed to the center of the car/grille) and the bumper upper side (which connect to the hood).
I noticed that the bumper, grille and hood are 99 whereas the headlight and fender are 96.
1. If this is the case, can I change back to 96?
2. Which is more cost effective btw buying 99 headlight, fender and bumper (was damaged) to make it 99 or buying 96 hood, grille, bumper to make it 96...?by the way i don't mind 96 look....
Thanks a lotz.... for helping me out....cheerzzzz....
Hi all,
Need a little help here. I wanna change my car name from previous owner to my name. I understand that need to take the car to PUSPAKOM for inspection. My car is a satria 1.3 fully stock engine and performance all stock except body kits. Fully modified bodykits (hood, fender, front bumper, rear bumper, side skirt and spoiler ) also i change da car paint from metallic black to matte black. Do i need to change back all to stock bodykits before i go for the inspection?
Thank you so...
